Brakes squeak after release
Old Sep 30, 2007 | 09:57 PM
aim4squirrels's Avatar
aim4squirrels
Default Brakes squeak after release
So today I bled the brake system out and now I have great, firm brakes but a squeak as I let go of the pedal. What did I do or forget to do?
I had to use some PB blaster on the bleeder screws as I bent a cheapo 3/8" wrench. I ran atube from the bleeder toajar of fluid per the FSM,and started from the farthest away and went to closest. I had some really black fluid pass thru in a couple of spurts on the back passenger side, but never got perfectly clean fluid to come thru. Put the cap back on and took it out for a test drive and the brakes were great, but squeaky on release. Is it possible that a rear wasn't working fora longtime andthe PB Blasterbroke some old crud free?
Old Oct 1, 2007 | 01:14 AM
Aubrey's Avatar
Aubrey
Default RE: Brakes squeak after release
I had something similar. Spent a lot chasing it. It was cheap pads and no brake quiet. Decent pads with the red brake quiet and fixed it.
Old Oct 1, 2007 | 12:01 PM
Dodge4x4810's Avatar
Dodge4x4810
I have the same problem, but i'm pretty sure it's coming from the drums in the rear.
