what is the biggest tire i can go with on stock dodge rims.
Old Oct 2, 2007 | 07:24 PM
ONECRAZYJEEP's Avatar
ONECRAZYJEEP
Default RE: what is the biggest tire i can go with on stock dodge rims.
what type of tires do you have and how significant is the wear? im getting the new tires in a week or so and need some ideas. should i stay with 265/75/18 or just go for it with the 285's? i dont want to get screwed on this. thanks much
robert
Old Oct 2, 2007 | 08:14 PM
Aubrey's Avatar
Aubrey
I have a 4x4 so I can't tell you what will really work on yours but I was running and wheeling 305/70/16s on my stock wheels and stock suspension.
Old Oct 3, 2007 | 01:23 AM
spaz_22's Avatar
spaz_22
probably the reason why your tires were wearing badly in the center is becuase your were running too high air pressure. What size do you have now on your truck? if you have 265/75/16's now, you should be able to fit 285/75/16's. Also i'm pretty sure your rims are 16 x 7's with about 5.25 inches of backspacing. your bolt pattern is 5 x 5.5 or 5x139.7(metric). if you want them to stick out alittle, about an inch, go with about 4.5 inches of backspacing on new rims..that's about the common for most rims...
Old Oct 3, 2007 | 10:38 AM
ICEMAN_CH's Avatar
ICEMAN_CH
The 285's that I have arn't wearing out that fast you can just tell that the middle section about 1" in on each side is wearing faster then the outside. It's not beecause of tire pressure. It's because the tire is slightly wider then the rim wich pinches the treads out causeing it to bow a little. It's not bad enough that I wouldn't recommend 285s. You should defenitly put 285s on. They look a ton better then 265s. Although I don't know if you will rub or not. From what I remeber4x4s sit higher then 2x4s.
Old Oct 3, 2007 | 06:35 PM
ONECRAZYJEEP
Yeah the 2wd sit about an inch or 2 lower. oh well ill make em work. thanks much anyother info would be nice thanks.
robert
Old Oct 4, 2007 | 12:28 AM
rabbler's Avatar
rabbler
ORIGINAL: ICEMAN_CH
The 285's that I have aren't wearing out that fast you can just tell that the middle section about 1" in on each side is wearing faster then the outside. It's not because of tire pressure. It's because the tire is slightly wider then the rim which pinches the treads out causing it to bow a little.
Your right...but so is Spaz.
If you drop your tire pressure a bit you can probably smooth out your tire wear. Lower pressure will cause more tire contact with the road.
I have the same issue with my 305's my stock rims are actually too narrow
Old Oct 4, 2007 | 12:37 AM
Cereal Killer's Avatar
Cereal Killer
I have 285s and I run them about 30-35psi to flatten them out a little bit. So far they're wearing evenly, if notbit much on the outsides on the front tires.
Old Oct 4, 2007 | 10:22 AM
BLKbeast's Avatar
BLKbeast
i have 315's on the stock 16s and they do NOT wear more in the middle....
Old Oct 4, 2007 | 12:43 PM
CALVIN305's Avatar
CALVIN305
i also have a 1500 2wd and i have 265/75/16 on stock rim and from what i was reading i think the largest we can go without any rubbing is 285/75. after that we need a aftermarket wheel.
im also going to put a bodylift on mine but i will also be adding later a 3" suspension lift. hoping to run 34" maybe even 35".
Old Oct 5, 2007 | 07:30 AM
ONECRAZYJEEP
THANKS FOR ALL THE INFO I GET MY LIFT ON TOMMARROW AND ILL POST PICS MONDAY. ILL BE GETTING TIRES SOON TOO. ILL POST BEFORES AND AFTERS. THANKS MUCH AGAIN
ROBERT.
