Right Turn Signal issues
Old Oct 2, 2007 | 09:42 PM
Deviantblis69's Avatar
Deviantblis69
Default Right Turn Signal issues
Ok folks I need help, suddenly my right turn signal will not work if I have my headlights on. WhenI turn the headlights off it works but I noticed it is blinking slower at that time as well! So I checked the bulbs(all ok)..so what's the deal here??
Old Oct 2, 2007 | 10:29 PM
flybyuin2.2's Avatar
flybyuin2.2
Default RE: Right Turn Signal issues
I would pull the bulb front/ rear andinspect them a little closer, also check the socket for corrosion and possibly change out the turn signal bulb to see if your problem goes away.
Old Oct 2, 2007 | 10:34 PM
IndyDodge's Avatar
IndyDodge
I would try and get ur hands on a wiring diagram and see if there is any common wires for ur head lights or common grounds something like that if it isnt something else that is obvious
Old Oct 2, 2007 | 10:40 PM
aim4squirrels's Avatar
aim4squirrels
You could just buy an orangutan to signal all your right turns.
Old Oct 2, 2007 | 11:00 PM
Deviantblis69
....so tomorrow I will either check into what everyone else suggested or get an orangutan mmm which would be easier? HAHAHAHA
RIGHT TURN CLYDE!!!
[IMG]local://upfiles/70381/55348CE411A7418E8094E7B28AF06592.jpg[/IMG]
