97 Ram wheel hub exploded - twice!
Old Oct 2, 2007 | 11:44 PM
redram09's Avatar
redram09
Default 97 Ram wheel hub exploded - twice!
My son was driving my 97 Ram at low speed - he had just pulled out of the driveway - when the drivers side wheel hub shattered. He didn't notice anything wrong prior and vehicle has 155,000 miles on it, so I figured it just went. When we pulled the wheel the castle nut was laying in the hub cover with fragments of the cotter pin. I pull the hub and replaced it. Also checked u-joints and they felt OK - no slop. 20 miles on new hub and it does the same thing. Any ideas??? What could lock the hub so tight it shatters. Also, nothing happens prior to this - no noise, no wobble, nothing.
Old Oct 3, 2007 | 03:29 AM
Chopper1's Avatar
Chopper1
Default RE: 97 Ram wheel hub exploded - twice!
Hub. Are you refering to the bearing assembly or the stub axle???
[IMG]local://upfiles/29187/7A4E83FFBECB4B46B89C96FA1CA31AC8.gif[/IMG]
[IMG]local://upfiles/29187/CCD073621F054DA9B2A0DE7F09DBC768.gif[/IMG]
Old Oct 3, 2007 | 06:48 AM
redram09's Avatar
redram09
It was the bearing assembly. Both times the outer wheel bearing in the hub fragmented.
Old Oct 4, 2007 | 02:12 PM
Chopper1's Avatar
Chopper1
Only thing I can think of is either the bearing assembly is to tight or the castle nut, threads,spline are bad. Axle moving outward/inward jamming it. Just guessing at this point. Been a few years since I had mine apart.
New nut, Check axle spline, make sure something isn't jamming the bearings.
Old Oct 5, 2007 | 03:17 PM
redram09's Avatar
redram09
Fixed it!!! The threads were fine, the castle nut was cracked but you could only see the split with a magnifying glass. Part shop replaced the $150 wheel hub as defective but I had to pony up another $360 for a new stub axle - the second break trashed the threads. Also had to replace the caliper bolts - bent, and the bushing bolts on the sway arm.Best news is no damage to gear box. Runs like a champ again. Thanks for the advice chopper1.
