Speed Sensor
Old Oct 4, 2007 | 09:14 PM
Ramit4714's Avatar
Ramit4714
Default Speed Sensor
I have a 1998 Ram 1500 and a little while ago the check engine light came on, so I went and had it plugged in and it came up as the O2 sensors and the speed sensor. I changed both O2 sensors and it the light came back on with the speed sensor. I was wondering if anyone has had this problem or knows something to do to fix it or how to fix it becuase I have never delt with a spped sensor. The truck has 35' tires on it, I'm not sure if that makes a difference or not but we can't even clear the code anymore. Thank You.
Old Oct 4, 2007 | 09:43 PM
dhvaughan's Avatar
dhvaughan
Default RE: Speed Sensor
there are 2 speed sensors. one in transmission (2wd) or t-case (4wd), and one in the top of the differential. neither is overly expensive, i think about $25-30. i don't know how to guess which one its talking about.
trasmission/t-case
http://www.rockauto.com/catalog/x,ca...,parttype,3988
both
http://www.rockauto.com/catalog/x,ca...parttype,10280
diff
http://www.rockauto.com/catalog/x,ca...,parttype,1912
http://www.rockauto.com/catalog/x,ca...parttype,10279
