IAC question plz hlp.
Old Oct 5, 2007 | 09:13 AM
BURNINGVAPORS's Avatar
BURNINGVAPORS
Default IAC question plz hlp.
ok should the iac make alot of noise at idle like its a turbo or a whistle? its a new one.
Old Oct 5, 2007 | 01:57 PM
95ram's Avatar
95ram
Default RE: IAC question plz hlp.
A new IAC may not help you much if the IAC plunger sealing surface in the throttle body isn't clean. To do a good job of that you'll have to remove the throttle body. There's a DIY on the site that goes into some detail. I just did this to my '95 Ram 5.2 and it was easy. As for the whistling sound, mine didn't make any noise, so I can't comment on that.
Old Oct 5, 2007 | 02:01 PM
Bouncer88's Avatar
Bouncer88
Mine makes a hissing sound because my buddy thought it would be cool to push it in and out, now I need a new one but it is honestly no big deal.
Old Oct 7, 2007 | 05:46 PM
dhvaughan's Avatar
dhvaughan
make sure you didn't forget the oring around the outside of the IAC body. that can cause some whistling.
Old Oct 7, 2007 | 07:58 PM
steve05ram360's Avatar
steve05ram360
it should not whistle... if you hear a whistle, your TB hat is not sealing on the TB. this is the cause 99% of the time. check the gasket on the TB/Hat and make sure it's not torn.
