How do you remove the seal on the timing chain cover?
Old Oct 9, 2007 | 06:50 PM
IndyRamMan's Avatar
IndyRamMan
Default How do you remove the seal on the timing chain cover?
Im trying to figgure out how to remove the crankshaft seal on the timing cover, and i can seem to do it.
Old Oct 9, 2007 | 08:08 PM
Bouncer88's Avatar
Bouncer88
Default RE: How do you remove the seal on the timing chain cover?
I think that you might need one of these to pull that seal out.
Old Oct 10, 2007 | 07:41 AM
dhvaughan's Avatar
dhvaughan
remove the timing cover from the front of the engine and set it up on the bench, then just knock it out from the back side using a hammer and punch/screwdriver. since your going to replace it anyway, it doesn't matter if you damage it.
Old Oct 10, 2007 | 08:17 AM
IndyRamMan's Avatar
IndyRamMan
ok, so when i put the new one in, does it just press in nice and hard?
Old Oct 11, 2007 | 12:30 AM
dhvaughan's Avatar
dhvaughan
yes. note the cavity that it seats into - it has a stop point. get it started straight, maybe put a block of wood over it, and tap it down to the stop point. oil the rubber lip before sliding it over the crank
