this is what i was looking for
Old Oct 10, 2007 | 06:23 PM
steve05ram360's Avatar
steve05ram360
Default RE: this is what i was looking for
glad to help... onther good thing you should do anyway is to put a 180* t-stat in it. the stock heads are prone to cracking between the valve seats, doing the 180 t-stat helps IMO. also, you may have 2 cats right after your exhaust manifolds, make sure they flow good and do not plug up. they will take out your exhaust seats on the #8 & #7 cylinders if it goes to long... ask me how I know [&:]
Old Oct 10, 2007 | 06:26 PM
2500 mopar's Avatar
2500 mopar
will i have problems if i change it? i have heard that people run into tons of problems when they did... let me know cause im gonna change the heater core and it would be the profect time to do it
Old Oct 10, 2007 | 06:29 PM
steve05ram360
you shouldnt have any problems changing the t-stat.. it's easy. use a genuine mopar gasket on it and you dont even need sealant on it, the sealant is in the gasket.
Old Oct 10, 2007 | 06:30 PM
2500 mopar's Avatar
2500 mopar
thanks a ton...
