tranny fluid
Old Oct 11, 2007 | 10:22 AM
lakelt's Avatar
lakelt
Default tranny fluid
I changed filter in tranny used atf III instead of II now it will not shift. Would the fluid cause this? Thanks
Old Oct 11, 2007 | 10:34 AM
Dodge4x4810's Avatar
Dodge4x4810
Default RE: tranny fluid
What year is your truck, to my knowledge, i believe that you're supposed to use ATF 3 for 2000 and early and ATF 4 for 2001 and later. But, to my knowledge you cannot buy ATF 3 anymore, at least not at the store. I just did mine with Mobil 1 fully synthetic, and that is supposed to be universal for all ATFs. Did you put enough fluid in, it should take about 4 quarts if it's just a drain and not a flush.
Old Oct 13, 2007 | 10:40 AM
pcfixerpro's Avatar
pcfixerpro
First of all, welcome to the forum LakeIt. I would double check the fluid level like suggested earlier, but I would not panic too much. Make sure your checking your fluid hot. Re-read the bottle's fine print, you may have picked up the right stuff after all. If you did get the wrong stuff, I would recomend a flush.
You are correct about the year usages to my knowledge as far as I know. You can most definately buy Type III dextron / Mercon at any autoparts store, at least in my area. In fact that same mobile 1 fully synthetic you refer to is infact Type III. Take a look here,and read the fine print. I bet you ment to say Type II, because I have never seen that before either. I ran across this problem when I needed trans fluid for my mustang. Isaw "recomended for all automatic transmissions" on the bottle but it was Type III when I needed Type F. It said forautomatic transmissions, but not for mine. Good thing I read the bottle before I dumped it in.
Good Luck!
pcfixerpro
Old Oct 13, 2007 | 10:55 AM
aim4squirrels's Avatar
aim4squirrels
I think you can put ATF +4 in aATF +3 tranny as far a safety factor goes (ATF +4 is a full syn and handles higher heat), but I'd make sure you get all the old ATF +3 out.
Old Oct 13, 2007 | 11:31 AM
dhvaughan's Avatar
dhvaughan
re-check what fluid you used.... you should use ATF+3 (no longer avail) or ATF+4 for Chrylser Products.
If you used Dextron/Mercon II or III (for chev) or Type F (for ford), then that is your problem and you need to get it out of there NOW. drop your pan and filter and leave the pan under it and let it sit for as long as possible, even overnight. it just keeps dripping and dripping and dripping. then refill with ATF +4 and drive it a little bit, and then change it again. an alternative to dropping the pan is to use a small hose and pump, maybe attached to a drill and pump it out. be aware that there is a significant amount of fluid in the radiator (cooler), lines, and the torque converter that doesn't come out by simply dropping the pan. and finally, check the fluid level while warm, in Neutral (not Park).
