Loose front end
Old Oct 12, 2007 | 01:53 AM
humboldtmatt's Avatar
humboldtmatt
Default Loose front end
I have a '99 Dodge Ram 1500, 2wd, club cab, 174k. The problem is that the front end seems to be getting looser and the trucks bounces a lot even on little potholes. I replaced all 4 shocks with new KYB's, and it doesn't sag. The truck also has new tires, and is in great shape otherwise. I took it to my mechanic who said that he "didn't see anything wrong." The problem seems to be getting worse and I need to figure out something to do asap. Any advice would be greatly appreciated.
Old Oct 12, 2007 | 04:25 AM
Bigdodge98's Avatar
Bigdodge98
Default RE: Loose front end
well it sounds like the tie rod ends steering box or even a warn sway bar could give u that play by letting the front axle shift side to side could be an idler arm or ball joints too u really gotta get under it and start checking all these components
Old Oct 13, 2007 | 10:55 AM
dhvaughan's Avatar
dhvaughan
take it to a front end shop and have them look at it. could be track bar, tie rods, ball joints or all 3. track bar is most common.
Old Oct 13, 2007 | 11:03 AM
aim4squirrels's Avatar
aim4squirrels
2wd drive did you say? Start by adjusting the steering box, there's a DIY at the top of the forum. That's the cheapest fix. It' it still has play you've got another problem.
Old Oct 13, 2007 | 11:20 AM
dhvaughan's Avatar
dhvaughan
ORIGINAL: aim4squirrels
oops.
Old Oct 13, 2007 | 11:58 AM
aim4squirrels
I do it a bunch myself.
