Steering Problems - Need advice
Old Nov 18, 2004 | 08:44 PM
Ramtuff's Avatar
Ramtuff
Default RE: Steering Problems - Need advice
ORIGINAL: waterbug1999
should you go for the whole $360 kit or the $45 rebuild kit? Im a newbie and dont know what the weak points are yet. thanks
You'd want the whole kit. The rebuild listed there is for their bar, not the factory one.
Old Nov 18, 2004 | 08:46 PM
Ramtuff's Avatar
Ramtuff
ORIGINAL: WA_Dodge_Owner
I do have the Solid Steel product on my truck with a 5" lift - it works with some lifts and not with others. The Tuff Country lift has spacers in the front that you bolt the Solid Steel part onto. It worked great for a while - but as I've found out, it didn't cover everything. (If you buy the part from Solid Steel - only $177 bucks - make sure you buy bigger washers for the bolts - mine were pulling through the metal on the spacers).
Ok, cool. I didn't know it would work with some lifts, so thanks for the info. The Solid Steel bracket is my list of things to get as soon as my Moog replacement wears out (already starting to get loose [:@]).
