What are you towing with a 1500 5.9?
Old Oct 15, 2007 | 12:50 AM
mgt46fast's Avatar
mgt46fast
Default RE: What are you towing with a 1500 5.9?
good question! I always pull my jetski with my dodge. Of course no problems, but overdrive is really out of power with any extra weight. I did make a 1300 mile trip with my 01 chevy camaro z28 that weights 3400 pounds on a uhaul trailer with 1000 pounds in the back of the bed. It pulled it pretty good but anything over 55 mph you can forget about it. Plus i drove straight through the hills of tenn.....Its a 01 1500 4x4 5.9 auto
Old Oct 15, 2007 | 08:24 AM
Bouncer88's Avatar
Bouncer88
Before I owned my Indy, my friend did, when he owned it we towed a 1989 jetta 360 miles to my house, 360 miles, 360 V8, what a coincidence.
Old Oct 15, 2007 | 10:20 AM
Glideman88's Avatar
Glideman88
ORIGINAL: mgt46fast
What gear ratio do you have?
I used to tow the travel trailer, allour camping equipment, 4 people and the ATV at 70 - 75 miles per hour down the Interstate all day long! The truck would usually get 8-9 mpg when I was working it.
We sold the camper so that's why I have the truck for sale. http://www.findcars.com/a.php3?q=242818
Old Oct 15, 2007 | 11:17 AM
CoastieJack's Avatar
CoastieJack
About 2000lbs worth of a VW, it was750 miles having owned the truck for all of four days. After awhile you forget it's back there.
Old Oct 15, 2007 | 12:27 PM
arcsum68's Avatar
arcsum68
My truck must still be broken, after replacing my clogged cat and putting a magnaflow on it, I took it out for a test run yesterday.
Went from 0-1500ft elevation over 22 miles yesterday, 4000+ pound trailer, 55mph, 3500 rpm on the grades, and my tranny overheated.
Tested the coolant and it was measuringat 20 degrees under what it should be protecting to, so I am going to flush that out today and try again.
Where should my rpm's be when pulling a trailer like this up a long grade? It wasnt as steep as its going to get, but long and consistent.
I feel like the truck should pull this trailer much easier than it does.
My friends 03 Tahoe with a 350 pulls it like its not even there, yet I totally feel like its a struggle.
Old Oct 15, 2007 | 12:54 PM
dillonjm's Avatar
dillonjm
That seems really high RPM for 55. Are you sure your tranny wasn't slipping? Mine runs like 2300 ish @ 55 I think 48 or so is 2000 RPM
Old Oct 15, 2007 | 12:57 PM
arcsum68's Avatar
arcsum68
How would I know if it was slipping?
It only has 20k on it since new, I would hope its not slipping, and that was up a grade, not on flat road.
Old Oct 15, 2007 | 03:37 PM
salmonman1's Avatar
salmonman1
I tow my travel trailer which is about 7000 lb with no problems.
Old Oct 15, 2007 | 03:41 PM
arcsum68's Avatar
arcsum68
Awesome, guess I need to start looking at other things now.
Any ideas?
Old Oct 15, 2007 | 05:13 PM
FRUITPORTCAT's Avatar
FRUITPORTCAT
Ive regularly moved a 450 Case dozer on a 3 axle trailer with my 98 5.2. A little sluggish but not bad.
