dual exhaust issues????
Old Oct 15, 2007 | 10:30 PM
jeepnut7261's Avatar
jeepnut7261
Default dual exhaust issues????
Are there any issues with a true dual exhaust on a 2001 5.9?
Headers, dual cats, etc.
Old Oct 15, 2007 | 10:33 PM
IndyRamMan's Avatar
IndyRamMan
Default RE: dual exhaust issues????
ORIGINAL: jeepnut7261
Idk about an 01, but the only thingI ran into an issue with was the rear 02 sensor not reading properly. If you put the o2s properly behind the cats, where they should be(unlike mine), I wouldnt suspect a problem
Old Oct 15, 2007 | 11:10 PM
Sirhilton17's Avatar
Sirhilton17
Ive herd these trucks dont like dual exhausts much, if you want duals they like SI/DO better.
After installing my SI/DO system I did feel a little difference in power... but not much.
I did drive it around with nothing after the cat just for fun, and it def ran better with the entire system.
Old Oct 15, 2007 | 11:11 PM
dillonjm's Avatar
dillonjm
If you build a true dual system I'd recommend putting an x-pipe or at the very least an h-pipe to equilize the pressures between the 2 sides.
Old Oct 15, 2007 | 11:41 PM
05DodgeRamHemi's Avatar
05DodgeRamHemi
Absolutely agree with the crossover pipe. It is just an essential if you are running a true dual. Without it, the exhaust will sound like ***, and you can lose power in certain power bands.
Old Oct 15, 2007 | 11:55 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: dillonjm
+1
Old Oct 16, 2007 | 09:14 AM
johnnyrocket5363's Avatar
johnnyrocket5363
Not to hijack(sorry!!!) but I have a 99 Ram 4X4 with a 5.2 5-speed...Is it better to run duals or to oversize where it comes off the manifolds(say, about 3 1/2") then to split to duals?
