Tranny Fluid
Old Oct 15, 2007 | 10:44 PM
hcast8's Avatar
hcast8
Default Tranny Fluid
Over the weekend I changed my tranny fluid and added Lucas Tranny Oil (3 quarts of ATF-4 and 1 quart of Lucas) which is really thick the next day it started shifting really hard I looked at another thread and it said that it probably needs 5 quarts added another one for a total of five quarts the hard shifting has continued but only has done about once a day should I add another one or re-drain it and not add any Lucas Tranny oil this time because thats when the problem started? Has anyone out there added Lucas to their tranny?
Old Oct 15, 2007 | 10:49 PM
jperkins812's Avatar
jperkins812
Default RE: Tranny Fluid
Were you having any problems before changing the fluid? I have put lucas in my cars and my truck before and never have had problems with it.
Old Oct 15, 2007 | 10:51 PM
hcast8's Avatar
hcast8
No there were no problems before it was just a routine change How many quarts did you fill up your tranny with? I have a 2000 Ram 5.9L
Old Oct 15, 2007 | 11:16 PM
dillonjm's Avatar
dillonjm
It depends. When you do a change by just dropping the pan I've added 5 before and had it up to proper fill and added another time added nearly 7.
Get the truck warmed up by driving it around a bit. Come to a stop, put on the e-brake and set the tranny in neutral. Get out and check your tranny dipstick. Add or subtract fluid to get it within the normal range.
Personally I'm not a fan of lucas stuff. Not only is it extremely thick in cold weather, but I've seen it foam up really bad before especially when used (esp in diffs), however I have never tried their tranny specific additive. I feel changing the fluid/filter when needed and replacing with clean ATF+4 alone is the way to go.
Old Oct 15, 2007 | 11:37 PM
bill022572's Avatar
bill022572
Been a tech for over 30 years and worked extensively on trans (mostly Toyota and Mitsubishi) and from what I know :any additives are not good for an auto trans. Just keep the fluid clean and change the filter periodically and should be fine. Personally I would get that additive out of there.
Old Oct 16, 2007 | 07:36 AM
dhvaughan's Avatar
dhvaughan
6-7 quarts to drop/refill pan. check level in neutral, not park.
if there were no problems before and now there are, i'd drain it out.
