cross drilled and slotted rotors
Old Oct 22, 2007 | 03:07 PM
1980blackfiveoh's Avatar
1980blackfiveoh
Default RE: cross drilled and slotted rotors
Here it is
Old Oct 22, 2007 | 03:44 PM
steve05ram360's Avatar
steve05ram360
ORIGINAL: GlenninTexas
I just finished changing out my rotors for SP Performance slotted, along with SP Perf. Severe duty pads and rebuilt calipers . I was concerned about the cross-drilled potentially warping under heavy braking. I've got a 2500 CTD used to haul a 5th wheel.I've replaced rotors 4 or 5 times (lost count) in 115k miles, each time the right outside pad wore down to the metal and ruined the rotors.
Hopefully the new calipers won't stick and ruin this setup.
did you grease the slide pin each time you worked on it? I used axle grease on it, a light coating is all you need and it'll never stick.
