cross drilled and slotted rotors
Old Oct 21, 2007 | 10:31 PM
1980blackfiveoh's Avatar
1980blackfiveoh
Default cross drilled and slotted rotors
Tomorrow is the big day! I install the slotted and drilled rotors, hopfully it will be worth the money. The work great on the 'stang. This summer was pretty hard on thebrakes: warped rotors and worn down pads. Shame I still have the stockrims becausethe rotorsare really hard to see.
Old Oct 21, 2007 | 11:48 PM
steve05ram360's Avatar
steve05ram360
Default RE: cross drilled and slotted rotors
cool, what did you go with? I had great luck with the powerstop setup.
Old Oct 22, 2007 | 01:21 AM
CSCustomCars's Avatar
CSCustomCars
Hey steve05, where'd ya get those powerstops? I'm in dire need of new brakes, and I agree that the stockers suck.
Old Oct 22, 2007 | 04:12 AM
steve05ram360
www.summitracing.com $30~40 bux more than what Napa had at the time.
Old Oct 22, 2007 | 11:15 AM
theshocker's Avatar
theshocker
ORIGINAL: CSCustomCars
Check out tirerack.com. They are running a special on powerslot rotors. I picked up a set for my truck @ $61.00 a peice. Thant is a pretty decent price.
Old Oct 22, 2007 | 11:47 AM
steve05ram360
that is an awesome price... IIRC last time I checked summit for the powerstops, they were $70 ea, toss in the pads and $11 bux for shipping and your good to go.
Old Oct 22, 2007 | 12:44 PM
1980blackfiveoh
Irun power stop on my 'stang: never warped them or had any problems. The ones for the ram are from an e-bay dealer:
brake labs. The rotors are crossed drilled and slotted while the power stops were only crossed drilled. It worked out to just under 200 with rotor and pads. I chickened outanddropped the truck off at a shop. It is pooring rain out and removing the rotors looks like a nightmare job. It looks like original rotors and I really doubt it will come off the hub nice.
Old Oct 22, 2007 | 12:56 PM
steve05ram360
that sucks... the swap is easy, less than an hour for both sides.
Old Oct 22, 2007 | 01:33 PM
GlenninTexas's Avatar
GlenninTexas
I just finished changing out my rotors for SP Performance slotted, along with SP Perf. Severe duty pads and rebuilt calipers . I was concerned about the cross-drilled potentially warping under heavy braking. I've got a 2500 CTD used to haul a 5th wheel.I've replaced rotors 4 or 5 times (lost count) in 115k miles, each time the right outside pad wore down to the metal and ruined the rotors.
Hopefully the new calipers won't stick and ruin this setup.
Old Oct 22, 2007 | 02:27 PM
1980blackfiveoh
I think (and hope) that the cross drilled are less likely to warp because they can disapate heat faster than standard rotors. I too haul a heavy 5th and that is partially the reason behind the worn out front brakes. I'll give it a shot.
