Brakes?
Old Oct 21, 2007 | 10:43 PM
Bigdodge98's Avatar
Bigdodge98
Default Brakes?
Is it me or am i the only one that seems like my truck doesnt have enough brake for the size ive got a 98 1500 5.9 extended cab and the brakes just suck even when i did everything new drums shoes rotors pads wheel cylenders ive done it all i was wondering if there is an upgrade for rear disc or something i can do to make it stop better
Old Oct 21, 2007 | 10:54 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: Brakes?
if you want to firm up the pedaland direct that force to the brake better, get a set of braid stainless steel brake lines. The rubber ones flex a lot when the brakes are stomped on.
For the rears there is an upgrade to a chevy or GMC 1 ton cylinder that'll cost you $40 and 3 hours time. Searchfor posts about 1 ton cylinders from a guy called The Burning Rom.
Old Oct 21, 2007 | 11:42 PM
steve05ram360's Avatar
steve05ram360
Default RE: Brakes?
powerstop pads & cross drilled rotors... made a huge difference on my 2000 ram...
Old Oct 25, 2007 | 01:19 AM
Bigdodge98's Avatar
Bigdodge98
Default RE: Brakes?
Yeah sounds good on those anyone no if the srt disc brakes can be converted to the 1500 series and anyone ever have a perportioning valve problem
Old Oct 25, 2007 | 01:56 AM
OlsenG_360's Avatar
OlsenG_360
Default RE: Brakes?
for whatever reason, the upgrade to bigger wheel cylinders in the rear was a very temporary fix for me. after a couple weeks it seemed like the rear brakes didn't work at all anymore, like the abs remembers that every time i hit the brakes hard the rear tires would lock for an instant, then the RWAL would kick in.
thought the rears might just need to be adjusted a little tighter, no help there at all. wonder what pulling the abs fuse would do, would i get my much betterstopping powerback?
Old Oct 27, 2007 | 05:17 PM
Sportster Bart's Avatar
Sportster Bart
Default RE: Brakes?
ORIGINAL: OlsenG_360
Bump. I'm curious too.
