cruise control
Old Oct 24, 2007 | 12:28 AM
jdb6194's Avatar
jdb6194
Default cruise control
just got 99 ram 1500 and cruise control doesn't work... any suggestions?
Old Oct 24, 2007 | 12:43 AM
rabbler's Avatar
rabbler
Default RE: cruise control
Could be a bad clock spring. Does the horn work? Air bag light on?
Check and make sure you have good vacuum to the cruise servo while the engine is running
Old Oct 24, 2007 | 10:55 PM
jdb6194's Avatar
jdb6194
the horn does work, but the air bag light is on... where would i look for the vacuum hose? If it is a bad clock spring, is that easy and cheap to replace?
Old Oct 24, 2007 | 11:25 PM
master tech's Avatar
master tech
Site Moderator & Tech
Ck under the battery. and follow the vacuum harness to the engine.
Old Oct 24, 2007 | 11:33 PM
rabbler's Avatar
rabbler
Clock spring is pretty easy to change. Just pull the steering wheel and a few electric plugs.
You might want to check with a dealer, there was a recall on that part for lots of trucks.
Old Oct 25, 2007 | 11:29 AM
starhm's Avatar
starhm
The brake pedal swith is another place to look. If the switch doesnt fully reset when the brake is released the cruise may sense brake applied and not engage even if it isnt enough to trip the brake lights. Good luck.
J
Old Oct 25, 2007 | 11:32 AM
ViperJ's Avatar
ViperJ
ORIGINAL: starhm
J
That was my problem when I got my truck, its a easy fix
