powerwindow malfunction
Old Nov 12, 2004 | 05:37 PM
SkullJoe's Avatar
SkullJoe
Default powerwindow malfunction
I don't know if anybody could help me on this, but any information would be helpful. I have a 2000 ram 1500 v-8 5.9 360 1/2ton truck and my drivers side window doesn't operate normally until I close the door. When I open and shut the door it's start to work okay,but now it's getting to the point that doesn't want to work at all. I can't tell if it's my switch or my window motor.
Old Nov 13, 2004 | 08:48 PM
Ramtuff's Avatar
Ramtuff
Default RE: powerwindow malfunction
Could be just the switch or a short in the wires. Check it with a test light first and visually inspect the wiring harness for any smooshed, pinched or torn areas.
Old Nov 13, 2004 | 09:10 PM
stic's Avatar
stic
on the same note....my drivers side window goes down smooth but when it goes up,it gets about half way and starts stuttering(for lack of a better term).itll make it all the way up,just that half way point where its like jumpin,or vibrating if you will.
anyone experience this?
thanx
Old Nov 13, 2004 | 09:12 PM
moparturd's Avatar
moparturd
Sounds like a bad wire to me, although I've had some really aggrevating experiences with window switches as well. Try to find somebody with a DC manual for your year truck. They have a continuity check for the switch that's a money saver.
Old Nov 13, 2004 | 09:23 PM
Ramtuff's Avatar
Ramtuff
ORIGINAL: stic
thanx
Could be a weak motor, loose track, or it might just need the tracks greased a little. Stop at your local auto parts store and pick up a spray can of white lithium grease. Shoot some down the window slot onto the tracks and see if it improves (might need a couple applications). It's a cheap way to see if you can eliminate the problem and you can always use it for other purposes (it's excellent for squeaky door hinges and the like). If that doesn't work, you can also pop off the interior door panel and check for a loose track.
Old Nov 14, 2004 | 01:20 AM
stic's Avatar
stic
k...ill do this tomorrow.
im a big fan of lith grease.that and silicone spray.if i have a squeak,ill shoot some slicone(dont hurt rubber)on a bushing,if the squeak stops...ive found my culprit.
does a loose track mean a new one or can they be tightened up?
Old Nov 14, 2004 | 03:36 AM
Ramtuff's Avatar
Ramtuff
I'm not sure how the tracks are attached on these newer Rams, but I'm sure you'd be be able to tighten it up one way or another. If's it's attached with bolts, then that's simple enough, but if it's attached by rivits you'd have to drill the loose rivit out an replace it with either another rivit or a bolt.
Old Nov 14, 2004 | 06:56 PM
stic's Avatar
stic
shot some silicone spray inbetween the rubber track on door and no more stutter.
sweet!
many thanx.
Old Nov 14, 2004 | 10:25 PM
Ramtuff's Avatar
Ramtuff
ORIGINAL: stic
Cool deal. I love easy fixes.
