Engine Check and very rough engine
Old Oct 26, 2007 | 08:00 PM
  #21
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: Engine Check and very rough engine
ORIGINAL: arcsum68
Just bought some of that electronic parts cleaner to try and clean off the sensors, and picked up a code reader.
A code P0308 may mean that one or more of the following has happened: [ul][*]Faulty spark plug or wire[*]Faulty coil (pack)[*]Faulty oxygen sensor(s)[*]Faulty fuel injector[*]Burned exhaust valve[*]Faulty catalytic converter(s)[*]Running out of fuel[*]Poor compression[*]Defective computer [/ul]
Im gonna replace my track bar and stabilizer links tonight, once thats done everything else should be cool enough for me to play around with.
The link you posted is dead, or at least for me.
Oh yeah, using premium gas on this tank, and roughly 3/4 of the way through it when the problem started.
WTF are you burning premium in that truck for? Plain jane unleaded. Period.
Old Oct 26, 2007 | 08:15 PM
  #22
WayneC's Avatar
WayneC
I couldn't get the page to load from the link either. My bookmark works well tho. I hope I'm not violating any laws here (probably am) but through the magic of copy and paste...
In response to several requests for more information about Oxygen (O2) sensors, perhaps the following information will help. Comment:
[ul]These procedures are only for self powered conventional sensors. Some very new cars are using a different style sensor that is powered. *Many* Oxygen sensors are replaced that are good to excellent. *Many* people don't know how to test them. They routinely last 50,000 or more miles, and if the engine is in good shape, can last the life of the car.[/ul] What does the O2 sensor do?
[ul]It is the primary measurement device for the fuel control computer in your car to know if the engine is too rich or too lean. The O2 sensor is active anytime it is hot enough, but the computer only uses this information in the closed loop mode. Closed loop is the operating mode where all engine control sensors including the Oxygen sensor are used to get best fuel economy, lowest emissions, and good power.[/ul] Should the O2 sensor be replaced when the sensor light comes on in your car?
[ul]Probably not, but you should test it to make sure it is alive and well. This assumes that the light you see is simply an emissions service reminder light and not a failure light. A reminder light is triggered by a mileage event (20-40,000 miles usually) or something like 2000 key start cycles. EGR dash lights usually fall into the reminder category. Consult your owners manual, auto repair manual, dealer, or repair shop for help on what your light means.[/ul] How do I know if my O2 sensor may be bad?
[ul]If your car has lost several miles per gallon of fuel economy and the usual tune up steps do not improve it. This *is not* a pointer to O2 failure, it just brings up the possibility. Vacuum leaks and ignition problems are common fuel economy destroyers. As mentioned by others, the on board computer may also set one of several failure "codes". If the computer has issued a code pertaining to the O2 sensor, the sensor and it's wiring should be tested. Usually when the sensor is bad, the engine will show some loss of power, and will not seem to respond quickly.[/ul] What will damage my O2 sensor?
[ul]Home or professional auto repairs that have used silicone gasket sealer that is not specifically labeled "Oxygen sensor safe", "Sensor safe", or something similar, if used in an area that is connected to the crankcase. This includes valve covers, oil pan, or nearly any other gasket or seal that controls engine oil. Leaded fuel will ruin the O2 sensor in a short time. If a car is running rich over a long period, the sensor may become plugged up or even destroyed. Just shorting out the sensor output wire will not usually hurt the sensor. This simply grounds the output voltage to zero. Once the wiring is repaired, the circuit operates normally. Undercoating, antifreeze or oil on the *outside* surface of the sensor can kill it. See how does an Oxygen sensor work.[/ul] Will testing the O2 sensor hurt it?
[ul]Almost always, the answer is no. You must be careful to not *apply* voltage to the sensor, but measuring it's output voltage is not harmful. As noted by other posters, a cheap voltmeter will not be accurate, but will cause no damage. This is *not* true if you try to measure the resistance of the sensor. Resistance measurements send voltage into a circuit and check the amount returning.[/ul] How does an O2 sensor work?
[ul]An Oxygen sensor is a chemical generator. It is constantly making a comparison between the Oxygen inside the exhaust manifold and air outside the engine. If this comparison shows little or no Oxygen in the exhaust manifold, a voltage is generated. The output of the sensor is usually between 0 and 1.1 volts. All spark combustion engines need the proper air fuel ratio to operate correctly. For gasoline this is 14.7 parts of air to one part of fuel. When the engine has more fuel than needed, all available Oxygen is consumed in the cylinder and gasses leaving through the exhaust contain almost no Oxygen. This sends out a voltage greater than 0.45 volts. If the engine is running lean, all fuel is burned, and the extra Oxygen leaves the cylinder and flows into the exhaust. In this case, the sensor voltage goes lower than 0.45 volts. Usually the output range seen seen is 0.2 to 0.7 volts.The sensor does not begin to generate it's full output until it reaches about 600 degrees F. Prior to this time the sensor is not conductive. It is as if the circuit between the sensor and computer is not complete. The mid point is about 0.45 volts. This is neither rich nor lean. A fully warm O2 sensor *will not spend any time at 0.45 volts*. In many cars, the computer sends out a bias voltage of 0.45 through the O2 sensor wire. If the sensor is not warm, or if the circuit is not complete, the computer picks up a steady 0.45 volts. Since the computer knows this is an "illegal" value, it judges the sensor to not be ready. It remains in open loop operation, and uses all sensors except the O2 to determine fuel delivery. Any time an engine is operated in open loop, it runs somewhat rich and makes more exhaust emissions. This translates into lost power, poor fuel economy and air pollution.The O2 sensor is constantly in a state of transition between high and low voltage. Manfucturers call this crossing of the 0.45 volt mark O2 cross counts. The higher the number of O2 cross counts, the better the sensor and other parts of the computer control system are working. It is important to remember that the O2 sensor is comparing the amount of Oxygen inside and outside the engine. If the outside of the sensor should become blocked, or coated with oil, sound insulation, undercoating or antifreeze, (among other things), this comparison is not possible.[/ul] How can I test my O2 sensor?
[ul]They can be tested both in the car and out. If you have a high impedance volt meter, the procedure is fairly simple. It will help you to have some background on the way the sensor does it's job. Read how does an O2 sensor work first.[/ul] Testing O2 sensors that are installed.
[ul]The engine must first be fully warm. If you have a defective thermostat, this test may not be possible due to a minimum temperature required for closed loop operation. Attach the positive lead of a high impedance DC voltmeter to the Oxygen sensor output wire. This wire should remain attached to the computer. You will have to back probe the connection or use a jumper wire to get access. The negative lead should be attached to a good clean ground on the engine block or accessory bracket. Cheap voltmeters will not give accurate results because they load down the circuit and absorb the voltage that they are attempting to measure. A acceptable value is 1,000,000 ohms/volt or more on the DC voltage. Most (if not all) digital voltmeters meet this need. Few (if any) non-powered analog (needle style) voltmeters do. Check the specs for your meter to find out. Set your meter to look for 1 volt DC. Many late model cars use a heated O2 sensor. These have either two or three wires instead of one. Heated sensors will have 12 volts on one lead, ground on the other, and the sensor signal on the third. If you have two or three wires, use a 15 or higher volt scale on the meter until you know which is the sensor output wire.When you turn the key on, do not start the engine. You should see a change in voltage on the meter in most late model cars. If not, check your connections. Next, check your leads to make sure you won't wrap up any wires in the belts, etc. then start the engine. You should run the engine above 2000 rpm for two minutes to warm the O2 sensor and try to get into closed loop. Closed loop operation is indicated by the sensor showing several cross counts per second. It may help to rev the engine between idle and about 3000 rpm several times. The computer recognizes the sensor as hot and active once there are several cross counts.You are looking for voltage to go above and below 0.45 volts. If you see less than 0.2 and more than 0.7 volts and the value changes rapidly, you are through, your sensor is good. If not, is it steady high (> 0.45) near 0.45 or steady low (< 0.45). If the voltage is near the middle, you may not be hot yet. Run the engine above 2000 rpm again. If the reading is steady low, add richness by partially closing the choke or adding some propane through the air intake. Be very careful if you work with any extra gasoline, you can easily be burned or have an explosion. If the voltage now rises above 0.7 to 0.9, and you can change it at will by changing the extra fuel, the O2 sensor is usually good.If the voltage is steady high, create a vacuum leak. Try pulling the PCV valve out of it's hose and letting air enter. You can also use the power brake vacuum supply hose. If this drives the voltage to 0.2 to 0.3 or less and you can control it at will by opening and closing the vacuum leak, the sensor is usually good.If you are not able to make a change either way, stop the engine, unhook the sensor wire from the computer harness, and reattach your voltmeter to the sensor output wire. Repeat the rich and lean steps. If you can't get the sensor voltage to change, and you have a good sensor and ground connection, try heating it once more. Repeat the rich and lean steps. If still no voltage or fixed voltage, you have a bad sensor.If you are not getting a voltage and the car has been running rich lately, the sensor may be carbon fouled. It is sometimes possible to clean a sensor in the car. Do this by unplugging the sensor harness, warming up the engine, and creating a lean condition at about 2000 rpm for 1 or 2 minutes. Create a big enough vacuum leak so that the engine begins to slow down. The extra heat will clean it off if possible. If not, it was dead anyway, no loss. In either case, fix the cause of the rich mixture and retest. If you don't, the new sensor will fail.[/ul] Testing O2 sensors on the workbench.
[ul]Use a high impedance DC voltmeter as above. Clamp the sensor in a vice, or use a plier or vice-grip to hold it. Clamp your negative voltmeter lead to the case, and the positive to the output wire. Use a propane torch set to high and the inner blue flame tip to heat the fluted or perforated area of the sensor. You should see a DC voltage of at least 0.6 within 20 seconds. If not, most likely cause is open circuit internally or lead fouling. If OK so far, remove from flame. You should see a drop to under 0.1 volt within 4 seconds. If not likely silicone fouled. If still OK, heat for two full minutes and watch for drops in voltage. Sometimes, the internal connections will open up under heat. This is the same a loose wire and is a failure. If the sensor is OK at this point, and will switch from high to low quickly as you move the flame, the sensor is good. Bear in mind that good or bad is relative, with port fuel injection needing faster information than carbureted systems.ANY O2 sensor that will generate 0.9 volts or more when heated, show 0.1 volts or less within one second of flame removal, AND pass the two minute heat test is good regardless of age. When replacing a sensor, don't miss the opportunity to use the test above on the replacement. This will calibrate your evaluation skills and save you money in the future. There is almost always *no* benefit in replacing an oxygen sensor that will pass the test in the first line of this paragraph.
[/ul]
Old Oct 26, 2007 | 08:16 PM
  #23
rabbler's Avatar
rabbler
P0308 is a #8 CYL mis fire.
check your spark plug and wire for that cylinder. I know you just replaced that stuff but anything can happen.
A compression test would be a good idea as would a fuel pressure test.
Old Oct 26, 2007 | 10:00 PM
  #24
arcsum68's Avatar
arcsum68
Sensors are cleaned, not gonna have time to test them tonight though. I will look at em again tomorrow.
Also gonna check the wire and plug tomorrow.
Premium was recommended on this forum because of the plenum leak.
http://www.mr2.com/TEXT/O2_Sensor.html
Try that link, same info. Thanks for all the responses.
Old Oct 26, 2007 | 10:06 PM
  #25
Gary-L's Avatar
Gary-L
Veteran: Navy
Injector #6 and #8 are prone to getting clogged on the inlet side. You *may* want to pull the fuel rail and see if the inlets on those injectors are clogged and/or if the fuel rail is clogged. I found that when I rebuild my engine. A search will yield my engine rebuilding thread(s).
Old Oct 26, 2007 | 11:23 PM
  #26
arcsum68's Avatar
arcsum68
Cool, thanks vwanddodge, I will do a search.
Is that a difficult procedure?
Old Oct 26, 2007 | 11:31 PM
  #27
rabbler's Avatar
rabbler
My #5 injector was plugged solid with rust, scale, crud, etc.
I removed the rail and the injector and gleaned out all the gunk by spraying carb cleaner directly into the injector inlet. Messy but it worked. 1 1/2 years and still going strong!
Old Oct 27, 2007 | 02:54 AM
  #28
BlueBeast2's Avatar
BlueBeast2
ORIGINAL: BlueBeast2
On mine it will show the code on the odometer it was have a P then a code number or say done which means none. My Ram does this at times too and I have replaced the IAC and TPS the surging idea went away but it still does this once in a while after it sits. Last night the CEL flashed for a min then went off. I checked for codes using the on off method and it showed none. It used to come on for a cyl 4 misfire I'm wondering if thats starting to act up again. Still have no idea what would cause that either
Came on today and stayed on checked and its that damn cyl 4 misfire. It went away for about a year and now its back. What the hell would cause this? Could it be teh cat like some of you have mentioned or maybe the fuel rail issue? I replaced plugs, wires, cap, and rotor back when is showed up before and it still did it then went away.
Not trying to hijack your thread arcsum68 but seems like we could having the same issue
Old Oct 27, 2007 | 11:47 AM
  #29
arcsum68's Avatar
arcsum68
No worries, hopefully gonna check some more stuff out today, I will report back either way.
Whats odd, is mine didnt do it in the morning at all for 2 days, just the afternoon. Now it does it all the time.
Old Oct 27, 2007 | 02:15 PM
  #30
1QUICK4's Avatar
1QUICK4
I am having the same problem with mine. It feels like it has no power at all and when you step on it it just sputters. Hooked up my brother's snap on modus and it said cylinder mis fire. Replaced the plugs, wires, cap and rotor and it still does it. I have yet to figure out this problem too.
