How much more of a difference will viper rockers make on my Indy?
Old Oct 28, 2007 | 08:10 PM
Bouncer88's Avatar
Bouncer88
Default How much more of a difference will viper rockers make on my Indy?
Well I bought some viper rockers off a guy locally , they are off a 99 GTS and are 1.7's. What kind of modifications do I need to do to install these , if any modifications and what kind of difference will they make.
Old Oct 28, 2007 | 09:45 PM
spaz_22's Avatar
spaz_22
Default RE: How much more of a difference will viper rockers make on my Indy?
there is some contriversy(sp?) over this on if they work or not. Some people say the feel a difference and some people say it throws your valve train geometry off. As for the most part it's a bolt on application where you just unbolt your old rockers and bolt these on, but some say the are not the viper rockers don't have the right pivot point to give the magnum motors a true 1.7 ratio, and thus throwing off your geometry....but let me know if you do feel any difference, it's a cheap enough mod though...i may try it if your results are good
Old Oct 28, 2007 | 09:51 PM
aim4squirrels's Avatar
aim4squirrels
My understanding is that the Viper rockers are a direct swap, cheaper than the Harland Sharps or Crowers, but not quite the same performance as I don't think there the roller kind. There were a couple of threads on this a while back, try a search.
Or here: https://dodgeforum.com/m_705984/tm.htm
You will see a gain from the added ratio, just not quite the same as the others
Old Oct 28, 2007 | 09:58 PM
aim4squirrels
Wait a minute! Bouncer, you posted there! What are you doing, testing my search function skillshere?
Old Oct 29, 2007 | 05:39 AM
Bouncer88's Avatar
Bouncer88
ORIGINAL: aim4squirrels
I was being extremely lazy after a hard 12 hour day of work, I kind of knew they were bolt on but didn't know if they would clear my valve covers.
Old Oct 29, 2007 | 06:50 AM
IndyRamMan's Avatar
IndyRamMan
i think they are from what i remember.
let me know how they are, snurf snurf.
