these chemicals for turbocharged?
Old Nov 2, 2007 | 09:17 AM
2500 mopar's Avatar
2500 mopar
Default these chemicals for turbocharged?
my brother has a 1998 mitsubishi eclipse spyder turbocharged so he wants to know if these will work so that he doesnt screw up his engine:
ENGINE RESTORE
SEAFOAM
Z MAX
also does z max work for our engines?
Old Nov 2, 2007 | 10:27 AM
ViperJ's Avatar
ViperJ
Default RE: these chemicals for turbocharged?
None of those will hurt the turbo since none of those will even come in contact with the turbo (except the engine restore) . How many miles on the eclipse?
Old Nov 4, 2007 | 08:33 PM
2500 mopar's Avatar
2500 mopar
eclipse has about 130000 miles, also seafoam can come in contact if you add it to your oil
Old Nov 4, 2007 | 08:38 PM
jperkins812's Avatar
jperkins812
On the back on each of the containers that the chemicals are in it should tell you if it is safe to use on turbochargered motors. I will have to look when I get back to work, but I think that Seafoam is not reconmended for a turbocharged vehicle.
Old Nov 4, 2007 | 08:52 PM
2500 mopar's Avatar
2500 mopar
anyone know about Z-MAX for our engines?
Old Nov 4, 2007 | 08:53 PM
OlsenG_360's Avatar
OlsenG_360
engine restore will come in contact with the turbo as well through the oil lines. i wouldn't use any of those on a turbocharged car, unless you want to put seafoam in the gas tank. turbo's oil seals are fragile enough as it is, i wouldn't chance it.
Old Nov 4, 2007 | 09:55 PM
jperkins812
I looked on Z-Max's website and I could not find anything about not being able to use it in turbocharged engines. I know that they had a testimonial section on their website and one of them from a trucking company that uses ZMax products in all of their trucks, and I know that all big trucks have turbo's. It would be worth checking into, because I have always heard good things about their additives.
Old Nov 4, 2007 | 10:45 PM
turbot_bird's Avatar
turbot_bird
I wouldnt use any additives in a turbo car. like metioned above these small turbos oil seals are fragile.
Old Nov 5, 2007 | 10:34 PM
THEGOLDPRO's Avatar
THEGOLDPRO
i used all three of them on my turbo car and never had a problem, i would'nt worry about it, the seafoam is actually remarkable if you do it right, i added it to the oil/gas and even added it to the breather hose sucking into my valve cover, i used to have slight lifter tick and when we did the seafoam it stopped it all together.
