missing?
Old Nov 4, 2007 | 02:24 PM
SilverRam_01's Avatar
SilverRam_01
Default missing?
Hey guys.... another rookie question.... I power washed my motor at the carwash, bcause it was covered with about an inch of mud and dirt, and then drove abou a mile home, and parked it for about 45 minutes.... got back in, started it, ran a little ragged, droppedit into reverse, ouched the gas, and it died. started it again, missing pretty bad, drove it around the block, got better, no miss when I got home. Anybody ever had this happen before? I'm thinking maybe water around the spark plugs in the heat shield that dripped off the inside of the hood while it was parked, and then it burned off, as i went around the block? I don't know... what do y'all think?
Old Nov 4, 2007 | 02:42 PM
Not even close's Avatar
Not even close
Default RE: missing?
Yep, happened to me once. I would usually wash the motor with the motor on but that didn't really make sense so I started using chemicals, like Simple Green, let it soak and just use a regular garden hose sprayer. I think it's also better to wash a cold engine as well. Sure others will chime in on this. With all the electronic crap, powerwashers are just too aggressive for an engine compartment, IMO.
Old Nov 4, 2007 | 02:56 PM
squishy_1010's Avatar
squishy_1010
Same thing happend to me once. Don't know what caused it but after it fixed itself I never had the problem again. Im curious to know what caused it also. Hopefully someone will know.
Old Nov 4, 2007 | 03:26 PM
jperkins812's Avatar
jperkins812
Like what was stated earlier, the high pressure from a power washer is hard on the electronics and you should only use a garden hose at the most. After driving the truck around for awhile it actually dries out the moisture buildup and aloows the vehicle to run right, most of the time. You should cover up all electronics with lastic bags and shield them from water anytime you are cleaning out under the hood with chemicals and water.
Old Nov 4, 2007 | 03:29 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: squishy_1010
Easy. Your electrical connections dried out and the problem disappeared.
Old Nov 4, 2007 | 04:32 PM
SilverRam_01
Thanks guys, yeah, I didn't get the sprayer nozzle too close, I just got the majority of the crap off, since i have duct tape holding my intake hat together... anyway.. thanks
Old Nov 4, 2007 | 07:00 PM
squishy_1010
ORIGINAL: VWandDodge
Yea. thats what i was figuring happened. thanks.
Old Nov 4, 2007 | 07:47 PM
Scottr1110's Avatar
Scottr1110
this has happened to me it was water in the first computer connector i took it off and dried it out and it was all good
