UGH..the dreaded mis-fire..
Old Nov 4, 2007 | 03:13 PM
Moparkid032's Avatar
Moparkid032
Default UGH..the dreaded mis-fire..
well i had a real bad mis-fire over the past week..got a p300-p305-and p307..today i took the dis. cap off and took a air gu and sprayed that whole area around incase water got in there..and sprayed some wd-40..well when i put everything back together it seems to drive alot better than it was before..but ican still feel a mis-fire...tomorrow ima yank the plugs from cyl. 5 and 7 and check to see if they are fouled...now should there be anything else i should check?
Old Nov 4, 2007 | 03:17 PM
motorbrreath's Avatar
motorbrreath
Default RE: UGH..the dreaded mis-fire..
check to see if they are gapped properly. also check your wires and make sure they aint interferein with each other
this website is a nice tool
http://dodgeram.info/Engine-Gas/index.html
Old Nov 4, 2007 | 03:36 PM
Moparkid032
thanks...ill try to get some pictures of the plugs for you gusy tomorrow..so you guys can be the judge of how bad they look
Old Nov 4, 2007 | 05:42 PM
the sarge's Avatar
the sarge
ORIGINAL: motorbrreath
nice website. Thanks
