heater core= done but now no start
so this past week i have been replacing my heater core a little each night. tonight i finished. i have everything in except the radiator is empty and the glovebox is not in. i reconnected the battery and the hazards were on i turned them off and tried to start it... i get no power to the fuel pump, starter, horn and airbags, and remote start andy suggestions? i will recheck my connections tomarrow and see if the romote start is the problem( there are 2 switches and they maybe causing the problem) anyone know what else it may be?
sounds like you knocked some connections loose under the steering wheel, check the fuse panel on the driver side dash and the big power block under the dash....i knocked mine around a little when i took mine out sunday
yea it was the large white harness i didnt have in all the way because there is a 3/8 inch bolt that tightens that one and i forgot to screw that in, after i screwed it in, reconnected the battery it was great...
