rust at bottom of doors
RE: rust at bottom of doors
Trying to park with the nose of the vehicle up hill may be worth it to keep the door drain working.
This product sprayed or poured into the seam at the bottom of the door might be better than plain motor oil:
http://www.eezox.com/
CorrosionX is also good:
http://www.skyvision.com/store/mi5500065.html
discussion of other corrosion fighting methods:
http://www.landlinemag.com/Archives/...st_jacking.htm
I took a closer look at mine and the drain holes are clear. It almost looks like it's just surface rust right at the bottom of the drivers door. I'll have a pro look at it and decide what to do. Maybe I can get lucky and just clean it up, spray on some primer and hit it with the bedliner stuff all along the bottom.
