rear lift?
Old Nov 8, 2007 | 08:40 PM
mgt46fast's Avatar
mgt46fast
Default rear lift?
what can i do to get my rear a little higher then the front. I hate how the front sits higher. Im not sure if it has a space on the front or my shocks are bad in the back. But the rea of my trucks sits lower. I have looked at the rear add a leaf lift and that seems good but i was ondering if i could just get a bigger block for the back. But i guess a extra leaf would help with loads. How hard ia an extra leaf to install. Something i can do in my drive way?
Old Nov 8, 2007 | 10:16 PM
padodgeram's Avatar
padodgeram
Default RE: rear lift?
AAL
Old Nov 9, 2007 | 09:55 AM
Silver_Dodge's Avatar
Silver_Dodge
Yup, an AAL is the best way in my opinion. Easy to install, you can definetly do it yourself assuming you have the tools. You will likely need longer u-bolts though, so plan ahead for that.
Old Nov 9, 2007 | 10:16 AM
zique's Avatar
zique
I'd say AAL as well. It helps your load rating while giving you the lift. Silver had it right too about the install. I did mine in about an hour per side, but the only reason it took so long was because the old u-bolts were so rusted on and stripped (previous owner, I promise[:@]) that I couldn't get them off.
