Ball Joint Emergency
Old 12-12-2007, 12:23 AM
kowboydmac's Avatar
kowboydmac
kowboydmac is offline
Default RE: Ball Joint Emergency
oh yeah, that's true. Glad I also found this site, very resourceful. I'm startin to get the hang of the search too. Now if only I could get a hit for a wiper switch and glove box...
  #82
Old 12-12-2007, 12:30 AM
ryans590's Avatar
ryans590
ryans590 is offline
wellglad one of us got the search figgured out....i give up on it, i just bookmark all the threads that intrest me.....
what do u need toknow about the wiper switch and glovebox?
  #83
Old 12-12-2007, 06:25 AM
HankL's Avatar
HankL
HankL is offline
a suggestion on 'search' here on DodgeForum
is that most of the time
the Advanced Google search
http://www.google.com/advanced_search?hl=en
works faster and returns more results
than the forum's internal search button
if on the line on Google Advanced that starts with
"Domain"
you restrict the Google search to
www.dodgeforum.com
there is an even more advanced search front page for Google at;
http://www.***anfinder.com/google.html
  #84
Old 12-12-2007, 07:28 AM
kowboydmac's Avatar
kowboydmac
ORIGINAL: ryans590
I aint a pro at it, but I returned some results that I wanted. I need a working Wiper switch and a glovebox that doesn't have a huge crack in it.
  #85
Old 12-12-2007, 10:18 PM
kowboydmac's Avatar
kowboydmac
Hey, I could use some advice about lowering the vehicle to set the joints and knuckle. I know I should get a floor jack, but since I have the 2wd with two seperate control arms, should I set the jack under the knuckle to lower the truck on, then raise it back up to put everything back together?
Also, what's a good way to clean up the bearings?
  #86
Old 12-13-2007, 12:20 PM
kowboydmac's Avatar
kowboydmac
Well I am close to being done now, just on hold for the floor jack (I jacked it up with my little hyrdo-thingy-ma-bob) to press in the knuckle and joints. Just wondering about if there is any pre-alignment adjustments I can make to save time and money.
  #87
Old 12-14-2007, 08:01 PM
kowboydmac's Avatar
kowboydmac
OKAY LADIES AND GENTS; I GOT THEM DONE!! Finally stuck in the cotters in about 20 min ago. No Squeky lol. I thought I was done, took it to pepboys to check out (only a block or two from my house) and they said no the lowers have to go more. And I have a leaky water pump. So, next project, water pump. lol.
Quick Reply: Ball Joint Emergency
