Wiring issue!!!
I just bought a 1500 Club cab less than 30 days ago and it has developed a nasty wiring problem. I have lost the radio, dome and cargo lights, power mirrors and the OBD II plug. I have a check engine light and cannot read the code due to the loss of the OBD II port. I would say it has to be a common pwr wire but without a diagram I don't know where to look. I have checked all the fuses with a meter and everything there checks out. Does anyone have good helpful advice?
trrdk.
trrdk.
I had a 99 that did the same thing but I also lost my headlights. I know you said you tested all the fuses but double check the protected fuse inside at the door. I checked all mine with a meter said it was good. Ended up changing it and no problems from then on.
