need help with 4x4.
Old Nov 12, 2007 | 09:31 PM
firedog's Avatar
firedog
Default need help with 4x4.
i have a 98 ram 1500. when i pull the lever to 4wd it doesn't engage and the light doesn't come on. what could this be?
Old Nov 12, 2007 | 09:34 PM
tazme695's Avatar
tazme695
Default RE: need help with 4x4.
DOES THE LINKAGE FEEL BOUND UP OR DO YOU FEEL THE POP?
Old Nov 12, 2007 | 10:23 PM
firedog's Avatar
firedog
it goes into gear fine. no binding. the front just doens't engage.
Old Nov 12, 2007 | 10:33 PM
Socha_62's Avatar
Socha_62
The front end isn't engaging, thats why the lights doesn't come on. Follow all the vacume lines that go from the front end up to the t-case. You have a vacuum leak
Old Nov 12, 2007 | 11:10 PM
nhlbill's Avatar
nhlbill
Look at the two connections on your front axle just to the passenger side of the middle of the axle. That is your CAD unit (central axle disconnect).
Your transfer case has vacuum lines coming out of it and traveling to the front axle CAD unit. When you shift your t-case lever into 4wd, the t-case vacuum linesthen operate the CAD which slides a locking collar over the passenger side inner and intermediate axle shafts thus locking them together as one peice and also creating a closed 12 volt circuit that lights the 4wd indicator light. This sliding action of the collar allows for your differential to power the passenger side wheel. Without this action, the power coming out of your transfer case and front driveshaft,would just spinthe spider gears (inside gears of your differential) and no torque would get to either the drivers or passenger wheels.
The most common failure with this type of 4wd system is that the connections on the CAD get hooked on things and become unplugged. Check both the vacuum lines and the 12 volt wires that connect to the CAD unit. If they are connected, follow the vacuum lines back to the top of your t-case and make sure that they are plugged in there as well. If they are plugged in at the top of the t-case, follow the vacuum lines over the back of the t-case and transmission to where they come up into the engine compartment just to the passenger side of the distributer cap. Make sure that the vacuum line has not become disconnected at the "t" in vacuum lines at that location as well.
Your vacuum for the CAD and t-case starts at the "T" connection next to the distributor cap, so that would be the location of origin for the 4wd vacuum.
Good luck, but I'm giving a better than 50/50 chance that the connecions on the CAD have become loose or detached.
If everything checks out with the vacuum lines, it is possible that the CAD unit is malfunctioning. You can check this by removing the 4-bolts that hold it to your axle and having someone operate the t-case lever and watch the CAD and see if it moves.
