Check Engine Light
Old Nov 15, 2007 | 02:44 PM
guerillawarfare's Avatar
guerillawarfare
Default Check Engine Light
I have a 98 Ram 1500. The CEL just came on and I would like to diagnose the problem.
Thanks
Old Nov 15, 2007 | 03:30 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: Check Engine Light
SEARCH is a wonderful function. Use it wisely.
Old Nov 15, 2007 | 05:17 PM
WayneC's Avatar
WayneC
ORIGINAL: VWandDodge
You are a card!
CEL is on...do you have a code reader? If so, whats your numbers? If not, get into the zone! They'll read it FREE!
Old Nov 15, 2007 | 05:18 PM
plafleursr's Avatar
plafleursr
First you need to find out what code is there. If you don't have a Scanner, sometimes you can goto local auto parts store ( I Mass we have Autozone ) they will read and clear code for you for FREE. Remember code and Post it back on here.
Old Nov 15, 2007 | 05:45 PM
priest1981's Avatar
priest1981
You can also cycle the ignition key off-run-off-run-off-run then the CEL will flash, you count the flashes and get the codes without going anywhere. When the CEL flashes it will flash 1-9 times then a short pause and 1-9 times if there are more than one codes then you will have a longer pause between sets of flashes. Using this process you will get two digit codes and you can use these to trobleshoot your trucks problem.
Will
Old Nov 15, 2007 | 06:15 PM
guerillawarfare
Thanks for the information. I tried to cycle the ignition, and got nothing, so I will go to autozone and get the codes.
Thanks again
Old Nov 15, 2007 | 08:26 PM
tazme695's Avatar
tazme695
KEY CYCLE SELF TEST IS PRE OBD II get the codes from someones scanner and post them ill get you what your looking for!
Old Nov 16, 2007 | 12:15 PM
priest1981's Avatar
priest1981
ORIGINAL: tazme695
Sorry, I thought it worked for a few years after OBD II, I'll have to check it out on my 98 when I get home.
Will
Old Nov 16, 2007 | 12:34 PM
ICEMAN_CH's Avatar
ICEMAN_CH
It does work on OBD-II I've used it before. On my truck it actually displays the code number where the odometer is read
Old Nov 16, 2007 | 01:12 PM
padodgeram's Avatar
padodgeram
ORIGINAL: ICEMAN_CH
but your truck is a OBD III . 2000 and up you can do the key thing maybe 99 , if that was the case i could do it to my 96 OBD II
