When i hit a bump i get a grinding noise help!
Old Nov 15, 2007 | 09:15 PM
bheadman's Avatar
bheadman
Default When i hit a bump i get a grinding noise help!
I just bought a 1998 dodge two days ago. It has 108000 miles a a 5.2 and a jet chip. I took it out in the woods cut some doughnuts went through some puddles and when i came out i get a grinding noise. It seems like its coming from the rear, its more vibration than grinding maybe something rubbing.Later on it goes away and comes back when i hit a bump then goes away again till i hit another bump. I checked under the truck nothings lose , driveshaft is firm, steering link is firm. i dont know what it could be i have 18 hrs before my lemon law expires plz help. Thanks
Old Nov 15, 2007 | 09:25 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: When i hit a bump i get a grinding noise help!
Just take it in and tell them about the grinding andthat they need to fix it.
Old Nov 15, 2007 | 10:02 PM
Ramafication's Avatar
Ramafication
could be many things as usual, it pays to play, you couldve blown a shock or losened up the mount, the stablizer bushings may be shot,and you just knocked em loose on your run or you havebad ball joints
