MSD FEEDBACK WANTED:
Old Nov 16, 2007 | 10:36 AM
dobbie146's Avatar
dobbie146
Default MSD FEEDBACK WANTED:
Im thinking of getting an msd ignition. I've done fipk, fastman tb, high flow cats, and 7.5mm performace mopar wires.
Are you guys running a msd 6a or 6al?
with a new coil and wires?... different plugs?... etc
Let me know your set-up as far as the ignition goes.[&:]
[align=left] [/align]
Old Nov 16, 2007 | 11:09 AM
padodgeram's Avatar
padodgeram
Default RE: MSD FEEDBACK WANTED:
MSD 6a , coil , SF wires 7.5mm using 3924 autolites factory gap running .035 , MSD gap at .040 max gap is .010 over factory.. smother idle any MPG made ..no..
Old Nov 17, 2007 | 06:33 AM
2k10HemiRam's Avatar
2k10HemiRam
Right now I'm just running autolite 3923's and 8.5 MSD wires but on tuesday I'll be adding the MSD blaster 3 coil to the mix. I would think about adding the box to the mix but here in a few months I'm going to have to bed my truck down (pretty much) for 2 years because I'm going out of country and cannot take my truck with me sadly.
Old Nov 17, 2007 | 01:01 PM
steve05ram360's Avatar
steve05ram360
had the off road version of the 6a box, ate up an Acell cap & rotor faster than the mopar ones. used the MSD 8.5's with autolite 3923's. smoothed out the idle some and seemed to give it a tad bit more low end torque. mpg... well at it's peak, I could get 14.5~15 hiway easily. around town 12's
Old Nov 17, 2007 | 10:34 PM
dobbie146's Avatar
dobbie146
im buying the 6a box this week, and need to know if my mopar performance 7.5mm will hold up, or if i should go bigger.
I need a new cap and rotor but have been putting it off because of its ****ty location. Are the brass ones still good with the msd setup?
Old Nov 18, 2007 | 12:29 AM
steve05ram360
go with the mopar cap & rotor... the wires should be fine. count on a cap & rotor swap about every 25~30k miles.
Old Nov 18, 2007 | 02:52 AM
IndyRamMan's Avatar
IndyRamMan
Accel cap and rotor, msd 8.5mm wires, blaster 3 coil, autolite 3923s. I dont have the 6a box, but thats next years ignition modification.
Old Nov 18, 2007 | 07:33 AM
steve05ram360
I'd still suggest the mopar cap & rotor... when I had the accel parts on there, they did not last as long as the mopar ones and I could not tell any difference in performance.
