my first "CHECK ENGINE" light
Old Nov 17, 2007 | 02:50 PM
CALVIN305's Avatar
CALVIN305
Default my first "CHECK ENGINE" light
took the dodge to autozone this morning and the code that came out was P0133 which said it was a o2 sensor bank 1 low voltage. that means it is the pre cat o2 sensor right? on a 1996 would that be on the Y pipe or on the cat just before it splits into the Y pipe?
is there any quick fixes? i know my gas mileage sucks so besides buying a new o2 sensor which i will prolly end up doing. is there anything i can do now?
btw. i did erased the code and the check engine light has not come back on. ive driven it about 20 miles now. is that normal? i would have thought it would still come back as bad.
thanks
Old Nov 17, 2007 | 04:02 PM
XXL 1500's Avatar
XXL 1500
Default RE: my first "CHECK ENGINE" light
p0133 is 1/1 o2 sensor slow response...
The following are possible causes for O2 Sensor Slow Response: exhaust leak, fuel
contamination, O2 sensor failure, electrical wiring connectors, electrical mechanical,
and O2 heater failure.
Turn Ignition On (Engine Off).
Using a voltmeter, backprobe O2S (Sensor Ground) Circuit between O2S Connector
(Sensor Ground) and PCM Connector (Sensor Ground).
Is the voltage drop reading below 0.10 VDC?
If YES- Replace o2 sensor
Old Apr 24, 2009 | 09:34 AM
gobbell1's Avatar
gobbell1
XXL 1500,
Could you explain the check procedure a little more in detail? I need to check mine and don't quite understand what you are saying.
thanks
Old Apr 24, 2009 | 11:02 AM
PartsChaser's Avatar
PartsChaser
You've been a member for a year and this is your first CEL? WOW! haha.
Old Apr 24, 2009 | 11:31 AM
postie1686's Avatar
postie1686
ive had my truck for 2 years and just got my first one about 3 weeks ago when i noticed my coolent level was going down but not leaking. dam cracked heads! had it not ideled rough i prolly wouldnt have cought it.
