Old Aug 6, 2015, 12:58 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
Halo headlight wiring
Old Nov 19, 2007 | 12:12 PM
Bhanson's Avatar
Bhanson
Default Halo headlight wiring
Hey i just got the black halo headlights today and of corse there is no directions for the wiring of the leds, and halo rings.I was just woundering if any of you guys know the best way to wire these up? thanks alot
Old Nov 19, 2007 | 01:33 PM
zique's Avatar
zique
Default RE: Halo headlight wiring
You can wire them however you would like (switch, no switch). One wire for + and one for -, that's it. Wiring you will need to look at is the blue connectors will need to get re-wired for your hi/lo to work correctly.
Old Nov 24, 2007 | 12:38 AM
Bhanson's Avatar
Bhanson
hey man thanks alot i got them put in yesterday they look awsome ill get some pics posted! so what do u i have to do to get the hi/low's to work right, right now the blue light on my dash for he brights is always on. does anyone know how to do the wireind for that?
Old Nov 24, 2007 | 02:03 AM
ryans590's Avatar
ryans590
if the high beam indicator is always on it guess its something with the DRL's there should be a module on the fender by the firewall under the master cylinder, unplug it and see what happens, with it unpluged the indicator wont com on at all but there is a way to fix that id just half to rember how, let me know if it works and ill find it
Old Nov 25, 2007 | 10:58 PM
Bhanson's Avatar
Bhanson
i havent had a chance yet to try unpluging that... but here is what is werid. when i pull my head light switch out my normal head lights are vary fante they dont even light up the road really, but then i can switch it to the brights and they come on but there not bright bright they just look like the normal head lights, its a really weird set up, when there dim both light bulbs are on. so idk i hope someone has a good answer for this thanks alot!
Old Nov 25, 2007 | 11:13 PM
ryans590's Avatar
ryans590
sounds like a ground problem, check the grounds to your headlights....
another stupid question but are you sure they are their right ones,your truck is made to have ither a 9004 or a 9007headlight bulb in it, they same bulb BUT the pin for low beam and the ground are reversed.....i cant remember for sure what bulbs are in ours (9004 or 9007) but it is one of the 2 and i know if you plug the wrong one in it will do what your describing
Old Nov 26, 2007 | 11:31 AM
Bhanson's Avatar
Bhanson
here is the link for the type of lights i bought http://bypass.digitaldisaster.net/in...dlbmFtZVpXRFZX
The the plug the lights came with fit just like a glove with my truck so idk
Old Nov 26, 2007 | 11:33 AM
Bhanson's Avatar
Bhanson
sry try this one http://cgi.ebay.com/ebaymotors/94-01...spagenameZWDVW
Old Nov 26, 2007 | 02:51 PM
zique's Avatar
zique
https://dodgeforum.com/m_842682/tm.htm
Old Nov 26, 2007 | 08:32 PM
ryans590's Avatar
ryans590
yah read through that link ziquegave you, sounds like the pins are wrong on yout truck, and sounds likr these lights are knowen to be wired wrong
