Few Questions-
Old Nov 19, 2007 | 01:31 PM
bldjello's Avatar
bldjello
Default Few Questions-
I got really screwed over with this truck, my brother gave it to me and does not know the first thing about maintenance.
the truck just rolled over 98,000 miles, still has original shocks, so i ordered new ones
http://www.autopartswarehouse.com/de...QKY344365.html(rear)
http://www.autopartswarehouse.com/de...QKY344066.html(front)
does anyone have any tips on how to get the job done?
he also left me with the airbox smashed so he basically had the airfilter laying on top of the throttle body. so i ordered this -
http://www.autopartswarehouse.com/de...335715031.html
that looks nothing like stock- but will it work?
heatercore wasnt working (and has been replaced before) so i just bypassed it.
and lastly, can someone take a picture of where the fuel filter is located, i cant seem to find it
thanks guys!
Old Nov 19, 2007 | 01:42 PM
padodgeram's Avatar
padodgeram
Default RE: Few Questions-
shocks will work , do a search on FIPK no more alot are using that set up , fuel filter is in the tank ..fuel pump ,filter are one unit...of course you can go cheap and get the fuel pump / filter replacement or spend some cash and get the whole unit.. either way its in the tank and that will need to be drop .. tip on changing your shocks is to soak those bolts *WD40 , PB*
Old Nov 19, 2007 | 02:10 PM
shott8283's Avatar
shott8283
pa's right.. if you search for "FIPK no more" youll find a thread.... ahhh hell.
good lord that took awhile.. either way. look this over and then decide on the intake..https://dodgeforum.com/m_613741/tm.htm
as far as the fuel pump/filter. why are you going after it?you didnt mention you having problems fuel wise in your truck.
