CEL
Old Nov 20, 2007 | 08:04 PM
phre0n's Avatar
phre0n
Default CEL
the other morning leaving from work.... the check engine light came on.... but the truck runs fine... went and had the code ran.. said i have a EVAP leak.. is this common in 2nd gen trucks? if it is.... is there a common spot for it to leak? whenever i get in the pedel, you can hear it kinda whistle as if the airbox wasnt tightened down on the TB.. any help would be great.. thanks
Old Nov 20, 2007 | 08:07 PM
DBG's Avatar
DBG
Default RE: CEL
bad gasket on the gas cap
Old Nov 20, 2007 | 08:19 PM
padodgeram's Avatar
padodgeram
Default RE: CEL
ORIGINAL: phre0n
The easiest answer would be check to make sure your gas cap is on (make sure it clicks couple times) , but since you can hear it whistle it could be a hose is loose ? under driver side there is a black can make sure your hoses are hook up to it , next for ****s and giggles check to make sure you have a gasket between the throttle body and your air cleaner.....
Old Nov 20, 2007 | 10:56 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: CEL
One other place to check: right next to theMAP sensor is a long tube with a rubber end that connects to the TB.Mine was cracked and it took 2 weeks for me to find the whistle.
