Water pump is leaking at the weep hole
Old Nov 21, 2007 | 08:24 AM
98RamSport360's Avatar
98RamSport360
Member
Default Water pump is leaking at the weep hole
I was going down the road the other day and my belt started to shriek so I popped the hood just to find coolant flying all over the place. It looked like I was running a small water park in my engine compartment. So now I get to do all the work I was going to do after Christmas. I am going to do a timing chain, water pump, plentum gasket, 180 T-Stat, Tune up and oil change. If I am forgetting something please let me know? I also have not figured if I was to advance my timing 4degrees or not, what would be the benefit for me to do so on my 98 1500 4x4 5.9?
ThanksRay
Old Nov 21, 2007 | 08:34 AM
turkeyhunter1962's Avatar
turkeyhunter1962
Default RE: Water pump is leaking at the weep hole
Dodge has developed a timing chain tensioner for our Magnum Engines that you may want to consider installing when you do your timing chain. It does double duty of keeping the timing chain at the correct tension and replaces the front camshaft plate between the camshaft timing gear and the block.
Old Nov 21, 2007 | 08:53 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: turkeyhunter1962
How much does it improve chain longevity/accuracy. (I hope im making sense this early in the morning)
Old Nov 21, 2007 | 09:36 AM
98RamSport360
Member
Where did you see this I can't seem to find anything on the internet. Is it offered as an aftermarket part?
Old Nov 21, 2007 | 12:21 PM
goldwing92's Avatar
goldwing92
The tensioner is listed in the Mopar Performance catalog
Old Nov 21, 2007 | 09:17 PM
turkeyhunter1962
TIMING CHAIN TENSIONER
Replaces the thrust plate,designed for all A engines and 3.9L,5.2L and 5.9L magnum engines.
5007709
Timing chain tensioner
29.95
http://www.mopartsracing.com/parts/ram.html
Old Nov 22, 2007 | 12:24 AM
dhvaughan's Avatar
dhvaughan
take a look at your oil pan gasket, valve cover gaskets, rear main seal, front seal, radiator hoses (upper and lower), heater hoses, water pump bypass hose, belt, belt tensioner, wires, plugs, cap, rotor, oil pressure sending unit, pcv valve, vac hoses (pcv, brake booster), rubber valve cover grommets (pcv and vent), temperature sending unit (its in a hidden little spot), thermostat, flush heater core and block (drain plugs behind engine mounts on each side), new anti-freeze. while your at it remove and clean out the coolant overflow tank. i don't have any experience on the 4* advance but Indy did it recently. Ask him about how it would be for daily driver because he runs his hard at the track.
