Fuel pump and fill tube????
Old Nov 24, 2007 | 07:09 AM
t_bell40's Avatar
t_bell40
Default Fuel pump and fill tube????
I recently was told by my mechanic that indeed it was a fuel pump my dodge '98 1500 needed. I went and baught the pump myself and saved 60 bucks. I was then told that it needs a fill tube as the old one is rusted badly. I said is it leaking? He said no but it could later. The fill tube is from the gas cover opening to the tank. It cost 80 dollars. It can only be baught from the stealer ship. Anyone know if it sounds like he is trying to get back the 60 i saved and then some???????????
Old Nov 24, 2007 | 10:14 AM
aim4squirrels's Avatar
aim4squirrels
Default RE: Fuel pump and fill tube????
Ask to see the part yourself and make a decision from there. It's your truck after all.
Old Nov 24, 2007 | 10:39 AM
motorbrreath's Avatar
motorbrreath
i have the same problem, mine leaks when i fill it up. if you move the gas nozzel around it wont leak as bad... i dont wanna pay 80 bucks for that little part.
Old Nov 24, 2007 | 11:24 AM
ICEMAN_CH's Avatar
ICEMAN_CH
Time for duct tape
Old Nov 24, 2007 | 11:40 AM
aim4squirrels
Here's a trick that "might" work:
Run a bead of silicone caulkinto a clear soda bottle and let it set up overnight. The next day, pour some gas in the bottle andlet it sit another day to see if the caulk dissolves.
Silicone should be inert,and not dissolve in the gas, but the medium which holds the caulk might dissolve, I'm not 100% sure. I know thechemicals that evaporate are gas soluble, but aftercaulk dries,if it doesn't dissolve you could use that to patch it up.
Old Nov 25, 2007 | 02:31 PM
t_bell40's Avatar
t_bell40
Thanks all!! I am going to take my mechanics word for it right now. I have already told them to save the part. If it looks good when i get there i will tell them i am disappointed and look elsewhere next time. If is does look bad then i guess i have peace of mind knowing that is one more thing that shouldn't fail. Happy Holiday!!!
Old Nov 25, 2007 | 03:44 PM
dhvaughan's Avatar
dhvaughan
motorbreath, if you can find where yours is leaking, JB Weld is good for patching steel gas tanks. just be careful with how it sags when wet, so guard against a lot of it running down inside the hole you are trying to patch. the jb 'quik' sets up a lot faster with less sag, and works better in some applications.
