1997 Diesel Woes
Old Nov 24, 2007 | 03:55 PM
big builder's Avatar
big builder
Default 1997 Diesel Woes
Hi Everyone.
I am new to this forum. Looks great.
I have a 1997 2500 4 by 4 diesel. 5 speed. It currently has 300 000 kms on it. It has been a great truck and has done more than it's share of work for me. I am sad to report she is a little sick right now.
It started with progessively harder to start. I had to touch the pedal a little to get it to start. Had to plug in on any nights colder than -10 cel. One day I was driving down the driveway and it just stalled. Then
it was had to start and finally went. I waited a while an then it seemed to drive fine. Now it is very difficult to start. It must b einside or plugged in and even then it is a rough start for 30 seconds or so.
I just had the manifold heater relays replaced.
How do I know that both heaters are working properly?
Does anyone have any ideas what else it could be. The mechanic mentioned it could be fuel pump or injector pump?
Thanks for any advice.
Old Nov 24, 2007 | 04:14 PM
ryans590's Avatar
ryans590
Default RE: 1997 Diesel Woes
how are your glow plugs?...you may want to try posting in the CTD section, they are the cummins goo roos
Old Nov 24, 2007 | 06:45 PM
Socha_62's Avatar
Socha_62
Does sound like glow plugs, but as for the stalling it could be some other stuff, but like he said post up in the Cummins forum on this website and those guys will probably know for sure!
Old Nov 24, 2007 | 07:35 PM
Kev_n_AZ's Avatar
Kev_n_AZ
hey guys. CUMINNS DO NOT have glow plugs!!!!!!!!!!
please post in the Dodge Cumminns Diesel section
https://dodgeforum.com/forumid_143/tt.htm
Old Nov 24, 2007 | 08:55 PM
ryans590's Avatar
ryans590
ORIGINAL: Kev_n_AZ
really? then what do they have? why do you half to "wate to start" then?
Old Nov 24, 2007 | 09:23 PM
goldwing92's Avatar
goldwing92
It uses a heater grid to heat the incoming air. The wait to start is to give the grid time to heat up.
Old Nov 24, 2007 | 09:28 PM
ryans590's Avatar
ryans590
hmm i dident know that are all CTD's like that (2nd and 3rd gen 5.9's and the new 6.7), i just always thought they had glow plugs
also insted of it being the glow plugs, maby its that heater grid that may need to be replaced
Old Nov 24, 2007 | 10:15 PM
rabbler's Avatar
rabbler
How long since you changed the fuel filter?
Could be a weak lift pump too
The newer Cummins 24v and common rail systems all use air intake heaters.
Check for power at the Intake heater on a cold start, and measure the resistance of the heater grid with an OHM meter.
Whats your idle speed in gear? If it's too low that can cause hard starting too.
