Transgo shift kit
Old Nov 25, 2007 | 11:25 PM
dodgenfox's Avatar
dodgenfox
Default Transgo shift kit
I see alot of post on the transgo shift kits. I am looking for some exact charactoristics. I have a 456 rear gear and I am running 20 inch wheels. The tire size is stock OD for this truck. I have a few modsbut nothing to strong. Will this make it bark in second gear at full throttle. I can smoke the tires about 30 feet with no problem but once second gear shifts the fun is over. Will this kit kill me in the snow? I have possi but as long as I am easy on the gas it does fine in the snow.
Old Nov 26, 2007 | 05:02 PM
tazman6789's Avatar
tazman6789
Default RE: Transgo shift kit
i have a transgo kit on mine mine wont bark into second but i also have bigger tires than stock. the shifts are def alot firmer, if your going slow the truck will jump a lil bit. May have better luck with smaller tires
Old Nov 26, 2007 | 05:21 PM
Midnight95's Avatar
Midnight95
can you get this for a 95 w/ 5.9? not sure what kind of transmission i have so just wandering? also where can you get these?
Old Nov 26, 2007 | 09:51 PM
dodgenfox's Avatar
dodgenfox
http://www.transmissionpartsusa.com/...-052930hd2.htm
This should get you there. Tazman6789 Thank You for the information.
Check to see what trans you have. I just found out I may have a 47RE.
