46RE Transmission Seal Being Changed, What else do I need to do?
Old Dec 5, 2007 | 06:37 PM
OE812's Avatar
OE812
Default 46RE Transmission Seal Being Changed, What else do I need to do?
On my 01 Ram 1500 automatic, the transmission seal is being replaced. What other items need addressing while the 46RE transmission is down from the engine?
Old Dec 5, 2007 | 10:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: 46RE Transmission Seal Being Changed, What else do I need to do?
Have the transmission cooler lines flush and replace the one way ck valve too. The one way ck valve is also part the cooler line.
Old Dec 6, 2007 | 06:10 AM
OE812's Avatar
OE812
Thanks master tech. The Dodge mechanic will be replacing the rear main crankshaft seal while it is down. For the flush and check valve replacement, is this a Dodge service item or can it be done at another commercial facility?
