1998 5.2ltr oil leak
Old Dec 8, 2007 | 09:26 AM
t_bell40's Avatar
t_bell40
Default 1998 5.2ltr oil leak
I just discovered an oil leak between the rear of my oil pan and the front of the transmission. It isn't leaking too badly. Does that sound like a rear main seal?? I don't have the fascilities or knowledge to do that one so, there goes another 1000 bucks. Just got the thing back for a fuel pump that went out. DANG!!!
Old Dec 8, 2007 | 09:35 AM
padodgeram's Avatar
padodgeram
Default RE: 1998 5.2ltr oil leak
yup its the rear main , just have to drop the oil pan to replace unless its a 2wd then you gotta lift the motor a little to drop the oil pain..then you gotta replace the front main and the oil pan gasket..
Old Dec 8, 2007 | 02:54 PM
t_bell40's Avatar
t_bell40
Did you mean if it is a 4 wheel drive?? Mine is 2 wheel drive. I am thinking it would be easier on a 2 wheel drive.
Old Dec 10, 2007 | 08:05 AM
t_bell40's Avatar
t_bell40
Did you mean 2 wheel drive is easier or 4 wheel??
