How often is it Okay to turn your OD off?
Old Dec 11, 2007 | 11:59 PM
Socha_62's Avatar
Socha_62
Default RE: How often is it Okay to turn your OD off?
You can do whatever you want with OD...its not gonna me a difference. The reason you were close to 3k RPM is because you were in 2nd gear, and a little over 2k your in 3rd.
Its not bad for the engine at all...
Old Dec 12, 2007 | 01:57 AM
DodgeFan01's Avatar
DodgeFan01
I believe its easier on the transmission when ur doing stop n go city driving with it 'off', and maybe not an increase in gas milage, but getting my full potential, in response to your quote.
Old Dec 12, 2007 | 02:50 AM
SilverRam_01's Avatar
SilverRam_01
ORIGINAL: DodgeFan01
easier on the tranny, so it doesn't have to shift into o/d for a second or whatever in town, correct?
Old Dec 12, 2007 | 06:31 AM
kurrz96ram's Avatar
kurrz96ram
I always shut o/d off unless I can get to 55 and stay there. You're tranny will thank you if you do this.
Old Dec 12, 2007 | 06:37 AM
HankL's Avatar
HankL
it is ok to manually shift out of OD
into 3rd gear with a locked torque converter clutch
prior to a hill
where you suspect the auto trans will downshift
the slight change you see in rpm is due to the torque converter clutch locking up quicker
when you manually shift down while still on flat ground
clutch wear wise
it is probably slightly better to downshift into locked up 3rd gear
at low engine torque when still on flat/downhill highway
rather than waiting for the trans to do an automatic shift at much higher engine torque
in the middle of the hill climb
there might also be a slight MPG gain
because by manually shifting beforehand the torque converter does not slip for as long a time as it will if the middle of the hill
Old Dec 12, 2007 | 07:26 AM
v10power's Avatar
v10power
I'm with everyone else, for normal city driving well actually anything under a consistant 55MPH i turn the overdrive off. It keeps so much wear and tear off your tranny. Even if you have a little less fuel ecomony it will be worth it in the long run if you don't need to replace/rebuild the tranny as often right? We all know them are not cheap!
Old Dec 12, 2007 | 05:07 PM
blkbaretta's Avatar
blkbaretta
Man you guys are great. Thanks a lot for all of the information. I'm just going to start leaving OD off since I mostly do in town driving. My longer trips whereI can go 55-60 I'll leave OD on, but for the most part I think I'll benefit if I leave it off. It's much more responsive that way, and the exhaust sounds better when coasting when OD is offand if it saves me on the stress on the tranny then that would be great. I really don't want to have to replace/rebuild one of those any time soon. Thanks again guys.
Old Dec 12, 2007 | 07:15 PM
WayneC's Avatar
WayneC
Don't be afraid of your transmission. They were made to shift. You can go in and out of OD all you want. Ditto for downshifting, i.e. up or down hills...won't hurt a thing.
Remember, you have eyes. You can see whats coming and can anticipate conditions more so than OD or cruise etc. They only RESPOND after the fact.
Old Dec 12, 2007 | 08:21 PM
blkbaretta's Avatar
blkbaretta
ORIGINAL: WayneC
Very good point. I guess the main reason I asked is because there are so many people who have these trannies to go out and I just want to make mine last as long as possible, and not do anything that could tear it up. I think, after all of this info I've been given, that it would probably help if I manually shift it. Like you said, since it's going to shift anyway, I know when to before it is forced to.
Old Dec 12, 2007 | 10:45 PM
aim4squirrels's Avatar
aim4squirrels
You'd be better served adding a tranny fluid cooler than worrying about OD on/off shifting.
Overheating's your main enemy, not clutch wear.
