ABS and E-Brake
Old Dec 12, 2007 | 07:35 PM
echseman's Avatar
echseman
Default ABS and E-Brake
Has anyone else had a problem with the ABS and parking brake lights in the dash? they stay on every once in a while. i am thinking a short somewhere, but wanted to check here before tearing anything up. thanks.
p.s. i usemy obd2-> usb data streamer, and i get no bad data when the lights 'stick' on.
Old Dec 12, 2007 | 08:45 PM
CSCustomCars's Avatar
CSCustomCars
Default RE: ABS and E-Brake
My RamCharger does that a lot. I think it may have something to do with the fact that the e-brake does not work, but it's partially engaged. Which make the dinsour of a computer think the ABS is screwed up.
I remember I read somewhere that when both lights come on there may be a problem with the ABS system. But if there was, it should throw some kind of code, although it may not present itself as a CEL. Is your scanner just a CEL scanner? Or does it check all codes through all systems?
Sorry if that's not much help, but I do know that when both lights come on there is a problem. I remember that specifically.
Old Dec 12, 2007 | 08:47 PM
CSCustomCars
maybe this post can help:
https://dodgeforum.com/m_963047/tm.htm
Old Dec 13, 2007 | 12:40 AM
echseman's Avatar
echseman
thanks CSCustomCars. my obd2 system streams all sensor data to my laptop in real-time. i have a ton of 3rd party applications that are compatible with the elm327, so you can pretty much do whatever with it. looks like i will be inspecting and maybe replacing my rear sensors. thanks again.
Old Dec 13, 2007 | 01:37 AM
CSCustomCars
Glad to have been of service
Old Dec 13, 2007 | 02:09 AM
nhlbill's Avatar
nhlbill
The rear wheel speed sensor is notorious for going bad on the 9.25. You can order them through NAPA (thats where I got mine) for around $40.00. They take maybe 5 minutes to change.
Good luck with it.
Old Dec 13, 2007 | 07:43 PM
echseman's Avatar
echseman
sweet. after this i have to rebuild my steering box. i have slop in the reduction gear somehow. oye.
