99 Ram V10 Band adjustment
Old Dec 13, 2007 | 02:28 PM
blackram2500's Avatar
blackram2500
Default 99 Ram V10 Band adjustment
Can anyone give me info on adjusting tranny bands on my 99 ram 2500 V10 4x4,as far as specs and procedure?
Old Dec 14, 2007 | 06:34 PM
XXL 1500's Avatar
XXL 1500
Default RE: 99 Ram V10 Band adjustment
The front (kickdown) band adjusting screw is located on the left side of the transmission case above the manual valve and throttle valve levers.
Raise vehicle.
Loosen band adjusting screw locknut Then back locknut off 3-5 turns. Be sure adjusting screw turns freely in case. Apply lubricant to screw threads if necessary.
Tighten band adjusting screw to 8 N·m (72 in. lbs.) torque with Inch Pound Torque Wrench 47RE TRANSMISSION Back off front band adjusting screw 1-7/8 turns.
Hold adjuster screw in position and tighten locknut to 41 N·m (30 ft. lbs.) torque.
------------------------------REAR BAND ADJUSTMENTThe transmission oil pan must be removed for access to the rear band adjusting screw.
Raise vehicle.
Remove transmission oil pan and drain fluid.
Loosen band adjusting screw locknut 5-6 turns. Be sure adjusting screw turns freely in lever.
Tighten adjusting screw to 8 N·m (72 in. lbs.) torque 47RE TRANSMISSIONBack off adjusting screw 3 turns.
Hold adjusting screw in place and tighten locknut to 34 N·m (25 ft. lbs.) torque. Position new gasket on oil pan and install pan on transmission. Tighten pan bolts to 17 N·m (13 ft. lbs.) torque.
Lower vehicle and refill transmission with Mopar® ATF +4
