Water pump.
Old Dec 14, 2007 | 08:22 PM
kowboydmac's Avatar
kowboydmac
Default Water pump.
After I got my BJ's done, I went to get an alignment, but found out the bottoms had come out so I had to repress them. Upon inspection, there was a slight leak coming from the water pump. My UTI buddy says use a little ATV and I believe that would work, considering it is a small leak and would just be a temp. fix, because I want to do the 180* Tstat and may as well stick a new water pump in while I'm at it. Any DIY writeups? Couldn't find any through the searches. Info is always appreciated.
Old Dec 14, 2007 | 10:26 PM
steve05ram360's Avatar
steve05ram360
Default RE: Water pump.
here you go... https://dodgeforum.com/m_224411/tm.htm
there is a DIY thread tacked to the top of the forum with alot of DIY links in it.
Old Dec 14, 2007 | 10:36 PM
kowboydmac's Avatar
kowboydmac
Awesome. Still thinking I'll go with some Sealant and see what that does. But great to know, I'll save over 200 bucks doing that. Throw in that thermostat and it's killin two birds with one stone.
Old Dec 15, 2007 | 10:30 AM
steve05ram360
if you do the t-stat, get a 180 and get a mopar gasket. it has sealant built into it so you dont have to add any. been using them for a long time and have never had one leak on me
Old Dec 16, 2007 | 12:21 PM
kowboydmac's Avatar
kowboydmac
Where's a good place to get Mopar parts?
