Fault Code 14 on 96 1500
Old Dec 15, 2007 | 05:25 PM
CowboyBob's Avatar
CowboyBob
Default Fault Code 14 on 96 1500
I just got a fault code of 14 on my 96 1500. Does this mean the MAP sensor needs replaced? If so where is it? Is there a DIY for replacing the MAP sensor????
Old Dec 15, 2007 | 06:44 PM
padodgeram's Avatar
padodgeram
Default RE: Fault Code 14 on 96 1500
Missing a few digits on the code , but if its the map sensor its on the TB up front , as soon you take the air cleaner off look down there it is..
Old Dec 15, 2007 | 10:44 PM
CowboyBob's Avatar
CowboyBob
I got fault code 14 from clicking the ignition 3 times. I took it to Autozone and they scanned it with an scanner and it came back with P0107 which is MAP sensor. I had them clear the codes and I changed the sensor. Was a lot easier than what I thought it would be.
