Why is it doing this
Old Dec 15, 2007 | 06:32 PM
99Ram1500sport's Avatar
99Ram1500sport
Default Why is it doing this
every time my truck hits about 45 to 50 MPH the truck becomes unresponsive. The RPMS will stay right at 1500. i could be driving on flat ground or driving up/ down hill and it will do this. i have to floor is before it will pick up again. am at a loss to why it does this any help will be appreciated.
Thanks
Old Dec 15, 2007 | 06:41 PM
padodgeram's Avatar
padodgeram
Default RE: Why is it doing this
maybe the cat is cloged..
Old Dec 15, 2007 | 06:44 PM
steve05ram360's Avatar
steve05ram360
lock out overdrive and see how it does. if it's much better than your looking at low bottom end power. what is your exhasut setup like?
Old Dec 15, 2007 | 06:48 PM
99Ram1500sport
the cats only 5 months old. my exhaust is single up to the muffler and dual out the the rear axle where it stops
Old Dec 15, 2007 | 07:02 PM
dhvaughan's Avatar
dhvaughan
my truck did that. i'd mash the gas a little and nothing would happen. mash it more - still nothing mash it a little more and it'd downshift and take off. i replaced throttle position sensor (TPS) and it got a lot better.
Old Dec 16, 2007 | 08:40 AM
99Ram1500sport
ORIGINAL: dhvaughan
that is exactally what mine is doin. I'll check TPS. I think its been replaced once already.
Old Dec 16, 2007 | 12:24 PM
99Ram1500sport
i turned OD off and had no problem
Old Dec 16, 2007 | 04:01 PM
Jr. Mechanic's Avatar
Jr. Mechanic
I would tighten the kick down cable then, it sounds like its not kicking down fast enough for your liking.
Old Dec 16, 2007 | 05:21 PM
Mowhawk's Avatar
Mowhawk
i have the same problem, what what is the kick down cable and where is it
Old Jan 2, 2008 | 01:39 AM
mr freeze's Avatar
mr freeze
Any one figure out about the kick down cable thing yet? I have the same problem.Between 1500 and 1800 there is like a deadend on power until you give it gas and make it go.
