alternator help..
Old Dec 18, 2007 | 01:50 PM
heybuddy1901's Avatar
heybuddy1901
Default alternator help..
was in class the other day doing tests on my truck and i have a shorted diode in my alternator, could explain alot of little issues ive been having..
anways.
first question.
the top bolt on the alternator, the big long one, is that a bracket it screws into that can be raplaced?? if not i need to helicoil mine cause its cross threaded like a ****.
2nd question.
wats the standard alternator for these trucks? 90 amp? i saw there was 3 options, the 65, 90, and 120.
thanks alot.
Old Dec 18, 2007 | 04:19 PM
rabbler's Avatar
rabbler
Default RE: alternator help..
1.Try running a tap down the hole ans see if you can clean up the threads
2. The most popular alternator was 120 amp unless you have the base v6 with no options.
Did you fix your alternator? It's nice when you know how things work and can sometimes fix it for $10 vs a 200 alternator.
Old Dec 18, 2007 | 08:33 PM
heybuddy1901
im gonna buy a new one since i dont really feel like pulling the thing apart to replace the diode trio, which i doubt a P.O.S. re-man like the one thats on it (previous owner) sells individually.
plus i can get a new one for like $160ish. 120 amp brand new, not a re-man.
and im pretty sure the re-man has a "lifetime warrenty" on it, so i can take it back and get some money out of it =] or use it as a core
Old Dec 19, 2007 | 07:28 AM
HankL's Avatar
HankL
some archived info that might be of use:
Jonathan
Subject: Re:Will high amp 53008651 alternator bolt on in place of
smaller ones? (welder-generator?)
Hank, I have swapped out the two differnt alternators
a few times without any problem. The one that's on the
motor right now is a 53027913, ans the spare in the
tool box is a 53008651. I don't even remember what
came stock on my truck.
--- Henry wrote:
> Will the larger 120 amp rated Ram pickup alternator
> bolt on in place of the
> lower amp rated alternators on the gasoline V8s ?
> Anyone do this swap already?
> On my 1995 alternator the nameplate says:
> 53008647
> 121000-3470 12V
> Family 90HS
> Denso
> Made in Japan 70113
> On page 8B-10 on the 1995 FSM it says the
> Denso 53008651 is rated 120 amps and has 7 grooves,
> whereas the 53008647 of Family 90HS is only rated 90
> amps.
> It also says the diesel has 8 grooves and is
> 56027221
Hank , I think you brought this up a few weeks ago. It piqued my
curiousity. The '98 Jeep Grand Cherokee 5.9V8's did come with a 150 amp
alternator from the factory. I'm guessing it had largely to do with the
electric fan that they also came with. I just picked one
up to see if it would work on my Dakota. The answer is, no for any vehicle
before 1998. Different
connectors than on my '95. I thought there had been a switch in terms of
connectors
at some point and it turns out that it was in '98 and up. The part number
for anyone that is curious is 56041394AA for this piece.
Old Dec 19, 2007 | 09:13 AM
mcss8541's Avatar
mcss8541
I have a 98 Ram with the 5.9L and I have installed electric fans would this alternator be a benefit?
Old Dec 19, 2007 | 09:16 AM
mcss8541's Avatar
mcss8541
Is that part no. The 98 Jeep Grand Cherokee 150 amp alt no?
Old Dec 19, 2007 | 09:53 AM
aim4squirrels's Avatar
aim4squirrels
I am currently running electric fans on the 117 Amp Alt that came stock. No problems and been running them since July. Just be sure to check the Amp pull on the fans. Most of the flex a lite fans pull far less amps than a Viper fan or the Lincoln Mark VIII fan that a few run. Not sure what the Ford Winstar fans pull.
Old Dec 19, 2007 | 09:56 AM
mcss8541's Avatar
mcss8541
Roger That will do.
Old Dec 19, 2007 | 12:18 PM
heybuddy1901
i dont have elec. fans
just trying to see what was the stock amp rating.
my local parts shop has it in a 90 and 120 amp version.. i think the price diff. is like 10 or 15$
just wondering if i was going to run into any problems going with the 120 Amp.
Old Dec 20, 2007 | 11:38 AM
mcss8541's Avatar
mcss8541
Well I plan on adding a winch to my truck and going with 2 yellow top optima batts so that heavier alt is looking real good right about now.
